He's a cool project with long term design requirements.
An underground file server...
You build the thing inside an industrial IP68 metal box (that wont rust/corrode over 10 years) Maybe use a proper time capsule or something.
Inside the box your mount...
- Low power PC like a raspberry pi (maybe even a second backup one)
- Reliable array of data storage (usb / ssd or server grade hdd etc..)
- Supercapacitor based backup power supply. Should be able to get an hour or so running a pi on supercaps.
- watchdog reset system with the ability to disconnect faulty peripherals that may die and prevent the PC from starting.
- 802.11n Wifi router plus a backup.
- Some sort of passive cooling system, eg all heat sources bolted to the metal box
- The only physical connection to the box is 230V power
- LED light and webcam inside, just for kicks.
Then you dig a big hole and bury the thing in your backyard so the top of it is ~10cm below ground level. Run underground power cable to it and fixed wire that to the house somewhere. (Ideally you'd use a radioisotope thermoelectric generator to power the thing, like the mars rover has, but getting one might be a little hard
The goal is to have something in your backyard that will run for 10+ years without physical maintenance. You'd control and talk to it over wifi.
You can store all your *ahem* legally purchased TV shows on it plus backup your files in case your house burns down.
