Hey guys! I was looking for some kind of printer and I found a Thermal printer in a POS device (that thing that shops use to charge you when you buy with your credit card).
Last time I saw it working was 4 years ago or so, but now it didn't power on, but I think it is because of a internal dead battery (which I measured exactly 0V, and it was a Lithium one). I didn't wanted to turn it on anyways... (Don't turn it on, take it apart!)
Back to the issue... Because it doesn't power on I can't measure it while printing. So I took it apart, and took some photos of it, maybe you can help me a bit.
What I know so far:
-It has a stepper motor, a four wires one, to move the paper
-It has a IR emitter and a receiver, to check if there is paper.
-One of the wires coming from the flat wire goes to one of the springs, so I automatically asumed that it is ground.
-Possibly 3.3v logic, since the LCD and some other parts works at that voltage. Not sure, just a though.
Anyone knows how to get it working? How can I test it without the original circuit working? Anyone used one of this before?
I leave you some pics, and no, there isn't a code to look it up on google. [emoji17]
