Just for clarity, what are my options if i want more precision in the design stage, other options beside schmitt?
You can look at monostables.
The better ones have two differential comparators and voltage dividers, so their tempco is much better and they will spec a data sheet band of 5-10% spreads.
eg the 4000 series HEF4538 has this design, and specs very good tempco, but will struggle down at 1us.
The HC4538 also explicitly shows comparators, which some of the other designs leave as blocks.
They all tend to get worse spreads at smaller times like 1us area, but again you could interpolate the curves like you already did.
eg TI's SN74AHC123A defines 866ns for 5V/10k/50pF, and then curves expect that to be +3% at 3v3, so you could hope for a typical value of 892ns, so 11.2k centres you on ~1.0us
The single gate 1G123 are another option.
Addit: because you are in the less-defined corner of monostable operation with 1us timing, another larger leap would be to look at small MCUs
Parts like SiLabs EFM8BB50 run 49MHz calibrated Osc, so you get 20ns jitter from the OSC sampling, and need it always on so you run at idle Icc on ~ 2.2mA, you save the external 1% Cap and 1% resistors per timing, and some very few lines of assembler would give you 1us (49 sysclocks) delays from interrupt-idle-exit.
I doubt you need that level of precision for a dead-band power sequencer.
