I've been working on building replacements for some of my old, bulky equipment (mostly just for fun), and the current contestant on Who Wants to Be Replaced is my Power Designs 2005 precision power supply. It's specified at 0.1% ± 1mV with five digit precision to 20.000V and 10ppm/°C; I'd like to at least match that, adding computer control, multiple outputs (one high precision and two lower precision, all operating off the same reference, part of my recent efforts related to automated testing) and better constant-current accuracy.
Here's what I have for the voltage reference board. Does anybody have any suggestions or corrections before I make it? Some of the parts are pretty expensive (free samples, hell yes - but I've only got one of each), so I don't want to screw it up. I'd especially rather not have to desolder the reference chip once it's been soldered on.
The following parts (at least - depending on what I can fit, I haven't done the PCB yet) will be under a small metal can with a heater, which is then surrounded by insulation, for thermal stability. (Gilding the lily a bit, most of this has good specs over a full typical ambient temperature range.) It will be kept at 50°C by an external PIC running a P-I algorithm.
- U2 (LM317, powers the reference) and its feedback resistors
- TL431 (powers U3 - missing a ref des... oh well)
- U1 (ADR4550 voltage reference, 2ppm/°C).
- Output voltage divider and trimmer.
- U3 (MCP6V06 output chopper amp).
- Of course, U4 (LM35 temperature sensor), and Q3 and Q4, the heaters.
Keep in mind, I've chosen some of the parts simply because I have them, so I know some of it isn't the most ideal design. Still, if my calculations are correct, I should be able to very easily achieve 1-3ppm/°C and hopefully better than that.
Edit: Removed the old schematic to not waste too much of Dave's server space. See below for updated.
