Author Topic: Thumbnail fan controller  (Read 1352 times)
Offline ElectronSurfTopic starter
  • Country: aq
« on: March 29, 2023, 11:43:09 am »
I needed to add fan control capability for my 100W electronic load, It has to be small and easy to plug it in where the fan supply socket is.
So I came up with this design and thought I share with you, it's a simple and useful circuit to have.
I suggest to use a voltage reference to set the threshold voltage and also a flyback diode is needed, I think with a SMD MOSFET it can be even smaller than 25x18 mm.
Link to the simulator.
- Don't judge my soldering, I was debugging this board!
« Last Edit: March 29, 2023, 12:02:48 pm by ElectronSurf »
Offline mariush
Re: Thumbnail fan controller
« Reply #1 on: March 29, 2023, 12:10:33 pm »
Or you could get a fan with PWM feature and a 6-8 pin micro can use ADC to read the resistor and adjust the pwm signal as needed.
Maybe even a 555 could be repurposed instead of a micro.
Offline shapirus
  • Country: ua
« Reply #2 on: March 29, 2023, 12:21:11 pm »
What's the purpose of the upper op amp?
  • Country: aq
« Reply #3 on: March 29, 2023, 02:49:18 pm »
Turning off the fan at a set temperature.
