I needed to add fan control capability for my
100W electronic load, It has to be small and easy to plug it in where the fan supply socket is.
So I came up with this design and thought I share with you, it's a simple and useful circuit to have.
I suggest to use a voltage reference to set the threshold voltage and also a flyback diode is needed, I think with a SMD MOSFET it can be even smaller than 25x18 mm.
Link to the simulator.
- Don't judge my soldering, I was debugging this board!
