EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
TLV1811 comparator setting into push pull mode
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: TLV1811 comparator setting into push pull mode (Read 887 times)
john23
Frequent Contributor
Country:
on:
October 06, 2024, 08:50:20 am »
Hello,I have the following TLV1811 component which is used as comparator.
In the datasheet on the headline they say it could be push pull or open drain output.
If the TLV1811 will be set as open drain then ill have to put pullup resistors.
How can I know that my TLV1811 is pushpull?
Thanks.
https://www.mouser.com/ProductDetail/Texas-Instruments/TLV1811LDBVR?qs=rQFj71Wb1eX09MzTfpxERg==
https://www.ti.com/lit/ds/symlink/t...=https%3A%2F%2Fwww.ti.com%2Fproduct%2FTLV1811
Logged
RandomUser
Contributor
Country:
Re: TLV1811 comparator setting into push pull mode
Reply #1 on:
October 06, 2024, 09:07:46 am »
Hi John,
the Trick is to read more then the title of the datadheet. On First Page it says TLV182x open-drain and TLV181x push pull, where x is the Number of channels.
Have a great day
Logged
Ian.M
eutectique
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
