Hello,
I’m using a TMCM-1290 evaluation board with a stepper motor and a phototransistor (GP1S093HCZ0F) for homing purposes. The board is connected via RS485 to USB.
The motor works perfectly, but I’m having trouble getting the sensor to interact with the motor. The sensor detects light at a single position, which should serve as the home position. Currently, the sensor itself works, but the motor does not respond when the sensor is activated.
The phototransistor is connected to the REF. SWITCHES input. I connected the cathode and emitter to GND, placed a resistor between the supply and the anode, and left the REF input connected to the collector. The board has a 4.7 kΩ pull-up resistor for the left REF input.
I tested by manually shorting LEFT REF to GND, which successfully triggered a logic low and caused the motor to respond to the TMCL code. However, this does not happen with the phototransistor connected.
Using a voltmeter, I measured 0.8 V between GND and the collector when light is detected, which the driver interprets as low, and 5 V when the light is off.
Any suggestions?
