I've already tried that, 0.3uA ish, and but when there's a multimeter in series, the output voltage doesn't increase by as much...
I've tried another sensor this time on 5V, same thing. Works fine until I connect the ADC, then it shoots up to 2.6v output instead of 250mV.
Also, I measured the voltage on the ADC input pin and it's up at 3.5ish volts, VCC is 3.6, is that normal?
