Author Topic: Tools for reversing a bluetooth protocol?  (Read 2550 times)
    • Mike's Electric Stuff
« on: September 01, 2024, 02:48:46 pm »
I have a big Bluetti powerbank, which I want to set up for solar EV charging -  the idea is it continuously charges from whatever solar is available, and when the SoC exceeds a particular level, it  turns on its AC output to dump the battery into the car via a normal granny-charger, and turns off below a specified level ( it will probably do the latter by itself anyway).
There is an Android App that allows access to all the info I need - SoC readback and AC on/off control.
I know very little about Bluetooth - can anyone recommend  any nice man-in-the-middle type tools for reversing a Bluetooth connection like this ?
The Bluetti does Bluetooth via a small sub-board with an ESP32, so sniffing the serial link to this would probably be a good first step - I suppose it could even be that the ESP32 provides a transparent COM port link, which should make things pretty easy.
Phase 2 would be to make a simple widget, maybe ESP32 based, to talk to the Bluetti and do this switching as a standalone unit, possibly as a product, hence  wanting to do this without modifying the powerbank.
Day Job: Mostly LEDs
Offline coppice
Re: Tools for reversing a bluetooth protocol?
« Reply #1 on: September 01, 2024, 02:53:38 pm »
Is it using classic BT or BTLE? In either case a lot of simple applications, where they have tacked on BT, use a COM port over the BT channel, but how you sniff is different. If you already have access to a UART port I'd start there, and get a hang of the protocol. Then have a look at the BT side. For BTLE I can recommend the Nordic dongles and the software Nordic supply for them. I'm not sure what a good tools for classic BT is these days.
Online ataradov
    • Personal site
« Reply #2 on: September 01, 2024, 03:26:11 pm »
I don't know if it will work in your case, but for a BLE sniffer I use this dongle from Nordic https://www.nordicsemi.com/Products/Development-hardware/nRF52840-Dongle
They have software that adapts it to Wireshark and it does all the decoding. It is cheap, works very well and easy to setup.
Also, ST has a generic Andorid app called ST BLE Toolbox. It just lets you connect to any BLE device and discover/read/write any characteristics. You may be able to figure it out just by using that app.
There is an app like this from all BLE IC vendors, but ST's is the best, at least from the ones I tried.
« Last Edit: September 01, 2024, 03:28:47 pm by ataradov »
Alex
The following users thanked this post: Nominal Animal, abeyer
Offline zapta
« Reply #3 on: September 02, 2024, 05:38:49 am »
+1 for wireshark and the nordic dongle. You can capture the packets with decoding at various stack levels.
Try also the Nordic nRF connect app for phones. It allows you to see the structure of the BLE endpoints that the device provides.
« Reply #4 on: September 02, 2024, 11:18:13 am »
AFIAK this probably uses classic Bluetooth (based on there not being any need for it to be BLE) - is this dongle any use for that? - AIUI the BT over-the-air traffic is encrypted.
Online RoGeorge
« Reply #5 on: September 02, 2024, 11:28:34 am »
Once I've tried to reverse engineer a BTLE bracelet.  Found this talk interesting, has both a video and a pdf with the slideshow used during the presentation:
Bluetooth: With Low Energy Comes Low Security
Authors: Mike Ryan, iSEC Partners
https://www.usenix.org/conference/woot13/workshop-program/presentation/ryan
As for tools, "nRF Connect" apk for Android might tell a lot about the radio link and the data packets.  Also, Nordic Semiconductor have some app notes (or it was in the user guide? don't recal) about their nRF IDE/toolchain and how to use that to debug a radio link.
« Last Edit: September 02, 2024, 11:37:58 am by RoGeorge »
Offline coppice
« Reply #6 on: September 02, 2024, 11:40:14 am »
It really depends on the age of the design. There are so many cheap BTLE solutions now, which can't do classic BT, that everything recent is BTLE unless speed demands classic BT.
« Reply #7 on: September 02, 2024, 11:48:08 am »
Actually you may be right here - the device does not appear in Android's list of BT devices - connection happens inside the app, so I'm guessing that would indicate BLE ?
Online nali
« Reply #8 on: September 02, 2024, 01:14:41 pm »
Just download nRF Connect and do a scan, it'll probably show up, and it'll show you what BLE services it's advertising.
Online ataradov
    • Personal site
« Reply #9 on: September 02, 2024, 01:48:18 pm »
I think both versions should appear in the list. But in Android there is a setting to hide device with no name in the advertisement. Sometimes IoT type devices use that to hide themselves from the list.
Download ST BLE Toolbox or nrF connect, they will show you all the information that is possible to get from the OS. I personally prefer the ST one, but ultimately they do the same thing.
Alex
Offline coppice
« Reply #10 on: September 02, 2024, 01:57:32 pm »
I don't think they are trying to hide anything. A lot of devices have just taken a serial port on their device, and attached a generic BTLE module that will pass that serial data through. They have done the minimum beyond that. So, they end up with a BTLE end point that looks exactly like the end point in a hundred other products using the same module. They only expect the device to have to communicate with their own app on a phone or tablet. If it does that, they are are good to go.
Offline Jon_S
« Reply #11 on: September 02, 2024, 04:03:26 pm »
As another option, you could attack it via that Android App using a tool like JADX. I did this with a BLE device but I can't see any major difference if it happens to be Bluetooth Classic.
I reversed the .APK and documented how the comms parts of it worked. Next I made a simple app with just the comms part re-implemented and debugged that until it worked properly.
This was possibly quicker than attacking it via the air as there was some basic protection on some of the data (XOR), and that was trivial to understand in the reversed code.
Offline joeqsmith
« Reply #12 on: July 31, 2025, 03:37:27 pm »
I asked the following question on NORDIC's Q&A site:
Can one PC be used for the central as well as for sniffing with Wireshark and nRF52840?
Yes, you can use a single PC both to act as a BLE central (for example, running your own application or using Nordic tools) and to sniff BLE traffic with Wireshark and an nRF52840 device programmed with the nRF Sniffer for Bluetooth LE firmware. The nRF52840 DK or Dongle connects to your PC via USB and appears as a hardware interface in Wireshark, allowing you to capture and analyze BLE packets in real time.
To do this, you need to:
    Program the nRF52840 DK or Dongle with the nRF Sniffer for Bluetooth LE firmware.
    Connect the sniffer device to your PC.
    Install Wireshark and the required sniffer plugins.
    Start your central application on the same PC.
    Open Wireshark, select the nRF Sniffer interface, and begin capturing packets.
This setup is supported and commonly used for BLE development and debugging. Just ensure that your sniffer device is physically positioned to receive the BLE packets between your central and peripheral devices. Also, if you are using a DK, it is recommended to use the nRF USB connector for higher throughput rather than the virtual COM port of the onboard interface MCU Running nRF Sniffer.
There are no explicit restrictions in the knowledge sources that prevent using the same PC for both roles, as long as you have the necessary hardware and software installed and configured correctly.
I have a BLE 5.0 dongle plugged into the same PC as the nRF52840.   The PC is talking to a peripheral and I want to sniff that.  However, as soon as the PC links to the device, WireShark shows no further packets between the two devices.   If I use a cell phone to communicate with the peripheral,  the nRF52840 has no problems collecting packets from advertising to connection.
Previously, I used an nRF5822.  When I used this with their "ble-sniffer_win_1.0.1_1111_Sniffer.exe" application, I could run both the sniffer and client software on the same PC.   When they changed to using Python, this no longer worked and I had to resort to using a cell phone to communicate with the peripheral.
Is there a work around to get the standalone PC configuration to work?
« Reply #13 on: July 31, 2025, 03:46:15 pm »
Just a follow-up - the BT/Wifi board was connected via RS485, and it was easier to just hook into that.
Some info on comamnds etc. here
http://electricstuff.co.uk/bluetti.html
Unfortunately The Bluetti has some bugs in the BMS that made it not as useful as I'd hoped
