Author Topic: TOP224Y vs TOP224YN differences ?  (Read 4318 times)
Offline slowpokeTopic starter
« on: October 09, 2014, 07:54:36 pm »
Hi.
Can i use TOP224YN instead of original TOP224Y ? Cant seem to find info on differences... (3terminal offline PWM switch,TOP224Y 75W).
The board i'm trying to repair is very tough on desoldering (big groundplanes, heatsinks etc), so by accident i ripped one of the leads off (facepalm). (then again, maybe i'm just rubbish at this in general...)
Ghrm...
Offline German_EE
Re: TOP224Y vs TOP224YN differences ?
« Reply #1 on: October 10, 2014, 10:42:17 am »
The YN version is ROHS compliant, there are no other differences (I just asked Mouser on your behalf because I was curious).
Warren Buffett
« Reply #2 on: October 14, 2014, 10:37:02 pm »
Thanks.
I'm having trouble locating analogues to parts that are end of life.
Any databases i could consult ?
Offline abpfischer
« Reply #3 on: July 16, 2022, 03:48:40 am »
What does the TOP224YN do? I have a Miele Coffee machine and the electronic board has one of these that has split and cracked in half. The machine no longer powers up so I thought I might be able to replace this? There seems to be a residual voltage left through here from the capacitor.
P.S. I am a complete novice.
Offline Colt45
« Reply #4 on: July 16, 2022, 05:15:18 am »
It's combined switched mode power supply controller and switch
https://www.mouser.com/datasheet/2/328/top221-227-1512604.pdf
Probably not the best thing to learn on, as there is no isolation and a few hundred volts on the primary circuit.
The following users thanked this post: abpfischer
Offline Gyro
« Reply #5 on: July 16, 2022, 08:46:44 am »
Please don't double post... https://www.eevblog.com/forum/beginners/top224yn/
Best Regards, Chris
Offline abpfischer
« Reply #6 on: July 16, 2022, 11:22:10 pm »
Attached is a picture of the blown switch. What could cause that?
Offline BrokenYugo
« Reply #7 on: July 18, 2022, 12:13:19 am »
Seems a lot of these all in one SMPS controllers in appliances are known to just go bang. Still, check for shorted parts and bad caps.
