So I previously posted on this forum asking for help
designing a tapped boost converter driver for a BXRC-50G10K1-C-73-SE LED, and
it did work, but it had some flaws.
Approximate ratings:
Input voltage: 12-24V
Output voltage: 70V
Output current: 2A
Obviously using an SMD MOSFET was a stupid idea cooling-wise, it should be replaced with a THT MOSFET that can be mounted to a heatsink.
Another issue I noticed is coil whine. Although the drive frequency is way above the range of human hearing, in the higher output power range the inductor seems to whine at an audible frequency, which I think is caused by the current feedback loop.
The output current ripple is also pretty bad, because it's driving an LED and as such a tiny amount of voltage ripple causes a lot of current ripple when the LED is just barely turning on.
I don't know if the efficiency of my design is optimal. I think that maybe creating a new design using a different topology will allow for a higher efficiency.
After some reading, namely
I think that designing a two switch forward booster will mitigate a number of problems that exist in my current design.
First of all, using a two switch forward will eliminate the voltage overshoots and ringing associated with traditional boost converters. This is due to the clamping diodes, which also eliminate the need for a snubber network. This will allow for lower voltage ratings on the MOSFETs, which will allow for lower forward voltage MOSFETs and thus lower power loss.
I think the output inductor would also result in a reduction in ripple on the output, though that's just a guess, I don't know if it will make a difference.
I'm not sure about the power losses in the clamping diodes though, considering they will be conducting quite a bit of current due to the boost topology. Two switch forward converters are usually used in step-down mode so I couldn't find any documentation on such a scenario.
I also don't know if there will be any voltage overshoots on the secondary side, and what diodes should be picked for it.
Obviously a two switch forward is more complex than a tapped boost converter. I'd have to either use a different controller IC that is capable of high-side and low-side switching, or I'd have to add a separate gate driver.
I'm really an amateur when it comes to these kinds of things, so any insight would be appreciated.
