Author Topic: [SOLVED] Transformerless power supply  (Read 2598 times)
Offline anishkgtTopic starter
  • Country: qa
    • George Hobby
« on: August 15, 2017, 04:22:49 pm »
hi All,
Is a transformerless power supply a good idea for microcontrollers like in the circuit attached ? i was thinking of replacing the transformer to cut down cost with a schematic like this http://www.electroschematics.com/5678/capacitor-power-supply/
Thanks in advance.
« Last Edit: August 15, 2017, 04:57:13 pm by anishkgt »
Online ataradov
    • Personal site
Re: Transformerless power supply
« Reply #1 on: August 15, 2017, 04:35:15 pm »
If you actually plan to use that FTDI while device is plugged into mains, then it is a horrible idea. You will end up killing USB ports, or yourself in the worst case.
Alex
  • Country: qa
    • George Hobby
« Reply #2 on: August 15, 2017, 04:37:03 pm »
Thanks alex.
The reason would be because the power supply is grounded and......what else
Online ataradov
    • Personal site
« Reply #3 on: August 15, 2017, 04:41:50 pm »
You will have potentially live voltage with minimal to no isolation exposed on the USB connector. It is just a bad idea all around.
You can use switching power supply, and small transformers are pretty cheap. You can probably even find complete sub-assembly at a decent price.
Your other option would be to power all low-voltage part from USB +5V, if device is constantly plugged in.
Or power FTDI from USB and use optocouplers to decouple it from the high-voltage part. Although this one also depends on what else on that board is accessible by the user. You don't want to have mains on encoder knobs either.
« Last Edit: August 15, 2017, 04:47:52 pm by ataradov »
Alex
  • Country: qa
    • George Hobby
« Reply #4 on: August 15, 2017, 04:56:47 pm »
you will have potentially live voltage with minimal to no isolation exposed on the USB connector. It is just a bad idea all around.
yea, i will just stick to the existing.
Offline M4trix
  • Country: hr
Re: [SOLVED] Transformerless power supply
« Reply #5 on: August 15, 2017, 05:34:14 pm »
@anishkgt,
regarding the TRIAC driving. From where you got that schematic ? What was the main purpose or what was the main load ?
Made in China is like a box of chocolates. You never know what you're gonna get.
  • Country: qa
    • George Hobby
« Reply #6 on: August 15, 2017, 07:10:38 pm »
The load is an MOT. The TRIAC driver schematic is in the data sheet of the driver itself. It's a dual SCR back to back.
Sent from my iPhone using Tapatalk
