Do the LEDs have to run at full current, for the desired brightness? Quite often 5mA is more than enough, so no h-bridge required.
What's the maximum forward voltage of the LEDs? What's the supply voltage? If there's enough headroom, just use emitter followers, then no base resistor is required, as the base current will set itself to the correct value.
