Author Topic: Triac 101  (Read 2310 times)
Offline NivagSwerdnaTopic starter
Triac 101
« on: July 09, 2023, 06:51:00 pm »
I've never done this before.... I have a door bell solenoid... ok... four of them that I wish to turn on and off using a ESP32
Literally years ago I came up with a little circuit...
But now it's come to the time to populate the board and I'm no longer convinced!
This is a one off and I've never used a Triac before so I am a bit worried.
Does this look reasonable?  AC voltage is 12V and control voltage is 3V3
Offline Benta
Re: Triac 101
« Reply #1 on: July 09, 2023, 06:59:49 pm »
LED current is too low.
MOC3021: 15 mA
MOC3022: 10 mA
MOC3023: 5 mA
What's the purpose of R4?
R3 looks low (depends on the triac).
Re: Triac 101
« Reply #2 on: July 10, 2023, 08:46:19 am »
TBH I'm not sure where I got this from but it is currently baked into the PCB.
I think R4 is to keep it stable off when the opto isn't active?
For the LED side... 15mA is max for a MOC3021... I think typical is 8mA is typical but maybe R1 is a bit high.
Does it matter which side the LOAD is applied?
Offline Benta
Re: Triac 101
« Reply #3 on: July 10, 2023, 11:07:47 am »
R4 is unnecessary and will probably impair performance.
I don't do designs using typical values, that's looking for trouble. But right now the LED is getting 6.5 mA.
Load can be applied both sides.
« Last Edit: July 10, 2023, 12:45:17 pm by Benta »
The following users thanked this post: NivagSwerdna
Offline PCB.Wiz
Re: Triac 101
« Reply #4 on: July 10, 2023, 08:07:56 pm »
Not quite.
Wiki says this
Because turn-ons are caused by internal capacitive currents flowing into the gate as a consequence of a high dv/dt, (i.e., rapid voltage change) a gate resistor or capacitor (or both in parallel) may be connected between the gate and MT1 to provide a low-impedance path to MT1 and further prevent false triggering. This, however, increases the required trigger current or adds latency due to capacitor charging. On the other hand, a resistor between the gate and MT1 helps draw leakage currents out of the device, thus improving the performance of the TRIAC at high temperature, where the maximum allowed dv/dt is lower. Values of resistors less than 1kΩ and capacitors of 100nF are generally suitable for this purpose, although the fine-tuning should be done on the particular device model.[5]
Renesas says this
For high-sensitivity and low-current thyristors, it is generally recommended to insert a resistor of 1 kΩ between the gate and the cathode.
Offline RoV
Re: Triac 101
« Reply #5 on: July 10, 2023, 08:20:38 pm »
I would put a small snubber in parallel with the load, to limit dV/dt. 100 nF class X2 in series with 100 ohm are sufficient, because low energy is expected (the triac opens close to zero current).
Offline Benta
Re: Triac 101
« Reply #6 on: July 10, 2023, 10:09:20 pm »
Not quite.
Wiki says this
Renesas says this
Well, the Z0103 is hardly high-sensitivity. And there's a certain difference between 300 and 1k.
Offline PCB.Wiz
Re: Triac 101
« Reply #7 on: July 10, 2023, 10:58:09 pm »
The supplier claims differently
Z0103MN0
Planar passivated very sensitive gate four quadrant triac
• Very sensitive gate in four quadrants
Gate trigger is 200uA~3mA
Offline Benta
Re: Triac 101
« Reply #8 on: July 10, 2023, 11:08:27 pm »
Well, you're (as always) right. Feel better?
Offline PCB.Wiz
Re: Triac 101
« Reply #9 on: July 11, 2023, 12:33:11 am »
Many people read these forums, over a long time, so it helps to have accurate information.  :-+
Offline bostonman
Re: Triac 101
« Reply #10 on: July 12, 2023, 02:28:59 am »
FYI, this month (or issue) of Nuts and Volts has a multi part series on TRIACs.
