Interesting. I thought because the gate controls each diode that it should have the same resistance from gate to either diode since (I thought) it was two separate diodes with one single gate.
You mean like this?
That "equivalent" always bothered me. It's kinda sorta true, but the two halves aren't designed symmetrically and turned around. Obviously, you'd only have a -6V or so range before the one explodes. Vkg is equivalent to Veb in BJTs. There's something missing here.
A more-correct diagram would show the right one as an upside-down PUT, or maybe a complementary one I guess. That is, the gate to the top of the triangle. And now the blocking voltage makes a little sense.
But it's more than that; the charge carriers from the one side, diffuse over to the other as well, and trigger the whole thing. Hence 4 quadrant operation (usually with one of them performing poorly, but still possible).
BTW, the correct way to wire SCRs together like this, if you should happen to need to (large TRIACs I think are less common than SCRs?), is to put a reverse shunt diode (K to G) rated for gate current, then a photoTRIAC between gates (and the specified limiting resistor, of course!). It always turns on whichever one is ready, by sinking current through one diode into the opposite gate, and the other one is always ready to block (with a whole cycle's worth of recovery time, not just the zero crossing recovery time for a TRIAC -- should be more reliable for weird loads).
Anyway, the trick with TRIACs is, the upper layers are both very wide (epitaxial?), so they block voltage either way. But given some charge injection from below, the whole stack becomes conductive, and more emission (of electrons and holes) results, hence positive feedback and it latches on. There's no forced / reverse recovery as for SCRs, diodes, and BJTs at turn-off (storage): TRIACs can only turn off by waiting for recombination, which takes 10s of µs, maybe even 100. Hence why they're basically only useful for mains frequency stuff.
