Hello experts,
I am developing firmware for a TypeK thermocouple which uses ADC AD7193 for TC voltage. Another cold junction temperature sensor is used. I use the lookup table to convert CJ to voltage, add it to ADC measurement and then use NIST polynomials(10 coeff) to get temperature. On measurement using a calibrated TC simulator, the ADC was producing offset and gain errors leading to difference of 2-3 degrees in worst cases. I did a simple two point (zero and maximum voltage) calibration(zero offset removal and gain multiplication) and was able to get more accuracy. I simulated a few points and typical accuracy was about 1 degrees. My question is although there is no 'one size fits all', what is the standard procedure for doing TC calibrations? How many points over the whole range (-200 to 1372) would be tested and calibrated against?
