Hi guys,
I designed a flyback converter using uc3844. when I power up the circuit , the voltage at the Vcc pin swings between the threshold ie approximately between 12 and 16V like a sawtooth waveform. I increase the startup current by reducing the startup resister but result in same. Can somebody figure out the problem
attached the schematics herewith
