Author Topic: ULQ2003A driver issues  (Read 11739 times)
Offline calexanian
    • Alex-Tronix
Re: ULQ2003A driver issues
« Reply #25 on: May 13, 2015, 10:28:42 pm »
Your common freewheeling diode pin should be tied to the supply voltage of the load. In this case 12 volt supply of your buzzer or whatever you have. Also with these make sure your MUC output is actually pulled low and not just tristate high. You may need to add pull down resistors.
Charles Alexanian
Alex-Tronix Control Systems
Offline wraper
  • Country: lv
« Reply #26 on: May 13, 2015, 10:59:14 pm »
There are pull downs inside of the ULQ2003A.
Offline cio74Topic starter
« Reply #27 on: May 13, 2015, 11:27:19 pm »
Found the problem, one PCB has LittleFuse TVS and the other AVX brand. Removing the AVX diode cured the issues.
Not all TVS are made the same...
Offline calexanian
    • Alex-Tronix
« Reply #28 on: May 14, 2015, 06:05:58 pm »
Sorry. Cobwebs in the brain. My brain went to VQ1000 chips for some reason. Another until recently discontinued driver chip. I should have been more on top of it because we use ULN2803's here in mass quantities and it is a similar driver chip. I think as my beard turns grey its pulling the smarts out of my brain, and i did not have much to start with!
Charles Alexanian
Offline jeff.remus
« Reply #29 on: May 16, 2015, 10:48:49 am »
Flux under the IC?
