Author Topic: Ultra-thin battery?  (Read 2212 times)
Offline jeduffyTopic starter
Ultra-thin battery?
« on: December 21, 2019, 06:56:02 am »
Does anyone know where I can buy cheap, very thin (<=1mm) batteries?
I don't really need any significant density (a few mAh is fine).  I've found a few places that make them, but no one that sells them for reasonable prices or in small quantity.
Application is I'm applying for jobs the next couple months and looking to make some circuit board business cards.
(can't do USB power, most companies don't allow plugging in unknown USB devices)
Offline sleemanj
  • Professional tightwad.
Re: Ultra-thin battery?
« Reply #1 on: December 21, 2019, 09:15:45 am »
A cr2012 or 2016 sunken into a routed out hole of your pcb with a flat strip soldered across the bottom and a formed sort of strip soldered on top to apply contact pressure could work?
NB: You might need to think about shipping issues if you intend to mail these cards, certainly no li-ion.
Offline rvalente
  • Country: br
« Reply #2 on: December 21, 2019, 09:43:00 am »
Offline I wanted a rude username
  • ... but this username is also acceptable.
« Reply #3 on: December 21, 2019, 09:46:47 am »
And you can get CR1616/CR2016 cells with surface-mount solder tabs to make assembly even easier. The canonical example being the original Arduboy.
Online SiliconWizard
« Reply #4 on: December 22, 2019, 04:34:55 pm »
Rechargeable or primary? (I suppose the latter?)
« Reply #5 on: December 30, 2019, 06:34:03 pm »
Alright, the OP never bothered to answer/follow-up, but since I have some pointers, I may as well list them, if it can be useful to anyone...
Primary batteries:
https://www.powerstream.com/thin-primary-lithium.htm
Primary and rechargeable:
https://www.pdbattery.com/ultra-thin-battery.html
A few years ago, "solid-state" batteries started to appear, but most seem abandoned now, so I'm guessing either the technology or the market wasn't quite there...
STM EFL700A39
THINERGY MEC201
Offline Nusa
« Reply #6 on: December 30, 2019, 06:56:06 pm »
Another option is forget about batteries entirely and use a thin solar cell. Plenty of credit-card calculators do exactly that.
