Author Topic: Understanding some GAL code...  (Read 5568 times)
Offline NivagSwerdnaTopic starter
« on: July 31, 2023, 02:27:34 pm »
I'm trying to understand some code which was extracted from a .JED image for a Data I/O EPROM programmer.
I ran the JED code through MAME's JEDUTIL and got this..
E:\mame>jedutil -view c:\Users\NivagSwerdna\Desktop\U13_V27.JED PAL16R4
Inputs:
2, 3, 4, 5, 6, 7, 8, 9, 12, 13, 14, 15, 16, 17, 18, 19
Outputs:
13 (Combinatorial, Output feedback output, Active low)
14 (Registered, Output feedback registered, Active low)
15 (Registered, Output feedback registered, Active low)
16 (Registered, Output feedback registered, Active low)
17 (Registered, Output feedback registered, Active low)
18 (Combinatorial, Output feedback output, Active low)
19 (Combinatorial, Output feedback output, Active low)
Equations:
/o13 =
o13.oe = vcc
/rf14 := /i3 & /rf14 +
         /i4 & /rf14 +
         i5 & /rf14 +
         i6 & /rf14 +
         i3 & i4 & /i5 & /i6 & i9
rf14.oe = OE
/rf15 := /i3 & /rf15 +
         /i4 & /rf15 +
         i5 & /rf15 +
         i6 & /rf15 +
         i3 & i4 & /i5 & /i6 & /i8
rf15.oe = OE
/rf16 := /i3 & /rf16 +
         /i4 & /rf16 +
         i5 & /rf16 +
         i6 & /rf16 +
         i3 & i4 & /i5 & /i6 & i7
rf16.oe = OE
/rf17 :=
rf17.oe = OE
/o18 = /i2 & /rf14
o18.oe = vcc
/o19 = /i2 & rf14
o19.oe = vcc
E:\mame>
One thing I would like to understand is what would be the state of the outputs on start-up given from the datasheet "All flip-flops power-up to a logic LOW for predictable
system initialization. "
For those playing along at home... pin 7, 8, 9 and 12 are connected to the databus d0, d1, d2, d3.  pins 3, 4, 5, and 6 are connected to the address bus A13, A14, A15 and RnW,  pin 1 is a clock nV02 determining when the bus is valid.
So here are my newbie questions...
Why /rf14 ?  Why not rf14?  In fact everything on the LHS seems to be not-ed?
I think the purpose is a 3 bit register that is addressed on a Write (i6=0) and A13=1, A14=1 and A15=0... i.e. to address 6xxx or 7xxx.  The register is subsequent used to provide address decoding to pins 15, 16, and 17 with a CS for one of two ROMs coming from pins 18 and 19.  18 and 19 are mutually exclusive and based on 14.
So at startup the "All flip-flops power-up to a logic LOW"... so that would make the flip-flop at 14 LOW?  so it should be low... but /rf14?  does that actually make pin14 output HI?
Device is PAL16R4
« Last Edit: July 31, 2023, 02:33:10 pm by NivagSwerdna »
Offline MarkS
Re: Understanding some GAL code...
« Reply #1 on: July 31, 2023, 02:56:19 pm »
The '/' character is the same as an overbar, i.e., active low.
« Reply #2 on: July 31, 2023, 03:44:13 pm »
I know.  So will the pin be 5V or GND at startup?
Offline MarkS
« Reply #3 on: July 31, 2023, 03:49:26 pm »
« Reply #4 on: July 31, 2023, 03:56:08 pm »
Because it's / ?  Would it be 0 if it was not "/"? i.e. not active low?
My datasheet specifies the register value being Zero... doesn't the actual pin value depend on if it is not-ed?
Offline MarkS
« Reply #5 on: July 31, 2023, 04:00:00 pm »
Someone else is going to have to jump in here. I can only go by the datasheet. From the POR description, I would think that the output is NOT the register value. So, if the register is 0, the output is 1 and vice versa. Truth be told, I have never messed with programable logic. I could be totally wrong, but it seems reasonable. My best advice would be to program the device and test it on a breadboard.
« Reply #6 on: July 31, 2023, 04:25:59 pm »
Sadly I don't have a blank 16R4
Online PCB.Wiz
« Reply #7 on: July 31, 2023, 06:43:00 pm »
Yes, there is a pin polarity fuse that can flip things.
The active low comment reflects that fuse value.
Most memories etc have ACTIVE LOW /OE and /CE
/pin = (equations) is the same as
pin = /(equations)
 If you have PLD SW like Atmel’s WinCUPL you can edit the report so it compiles, and then simulate the pld.
That can create a .JED file with fuse and test vectors, the programmer runs to test operation after programming.
« Reply #8 on: August 01, 2023, 10:37:11 am »
I don't speak CUPL.  But I could give it a try.
It looks like the /pin term is used where the inverter on the output can be used to assist in the reduction of terms.  So it looks like when that has happened the inverter is in circuit.
But looking at the datasheet... (see attached)
You cannot get out of the flip flop without being inverted at the transceiver buffer.
So... logically if the flip flop assumes LO at start-up then the output would have to be HI?
Online PCB.Wiz
« Reply #9 on: August 01, 2023, 04:12:39 pm »
They draw these using some default, but the polarity fuse can flip as needed.
See
https://blog.frankdecaire.com/2017/02/25/programming-the-gal22v10/
Do you need to change parts, or just copy what you have, or just extract eqns for servicing  ?
You can also usually also edit test vectors directly inside programmer sw, so a few lines is enough for simple code like this.
Just enter 1,0,H,L,Z,C,K,N for each pin.
« Reply #10 on: August 01, 2023, 06:55:31 pm »
So I tried a crash course in WinCPL...
Name     DECODE;
PartNo   00;
Date     01/08/2023 ;
Revision 01 ;
Designer Engineer ;
Company  ACME ;
Assembly None ;
Location  ;
Device   g16v8 ;
/* *************** INPUT PINS *********************/
PIN    1 = CLK                        ; /*                                 */
PIN    2 = i2                        ; /*                                 */
/* *************** OUTPUT PINS *********************/
PIN    14 = !O1                         ; /*                                 */
O1.D = i2;
Admittedly this is a different part but the principle may the same...
And I ran a simulation...
So here Pin 14 is !O1
The simulation shows that the Pin 14 will be 0V until a value has been CLKed into O1.
So now I'm not sure again... I would have expected the opposite!
« Reply #11 on: August 01, 2023, 07:04:47 pm »
Reading the GAL16V8 datasheet is even less understandable... The simulation shows 0V...
Online PCB.Wiz
« Reply #12 on: August 01, 2023, 10:24:40 pm »
You also need care that a NOT can simulate as positive but invert at the pin. The O1 here is FF.Q upstream of the pin, and the pin-flip nature means the pin is not the sim waveform
Sometimes it's best to try an actual device :)
My recollection is that a leading NOT 'ripples thru to the fuse', so I tried this
PIN    15 = ChkPolA                     ; /*                                 */
PIN    16 = ChkPolB                     ; /*                                 */
O1.D = i2;
ChkPolA.D = !i2;
!ChkPolB.D = !i2;
and that report in the .DOC file as
Pin #16  02051  Pol x  02123  Ac1 x
Pin #15  02052  Pol -  02124  Ac1 x
Pin #14  02053  Pol x  02125  Ac1 x
and my test cases do have opposite polarity fuses, which is a good sign.  The difference here will be how they POR.
but a different part of the same DOC file reports this
Pin Variable                                    Pterms   Max     Min
Pol   Name              Ext     Pin     Type     Used   Pterms  Level
    CLK                         1        V        -       -       -
    ChkPolA             d       15       X        1       8       1
    ChkPolB             d       16       X        1       8       1
 !  O1                  d       14       X        1       8       1
    i2                          2        V        -       -       -
not the same pol pattern as the fuse reports ?
Running a sim, gives a POR indication that not all POR the same, but this follows the Pol column not the fuse map info  :-//
           CC
           hh
           kk
           PP
      C    oo
      Li  Oll
      K2  1AB
 Power on checks
0001: 00  LHH
0002: C0  LHL
0003: C0  LHL
0004: C1  HLH
0005: C1  HLH
Sim is happy with either !ChkPolB, or ChkPolB, but which one matches the physical pin behaviour ?
When you run a SIM, the JED file has the test vectors included, so a programmer can check a real device after program.
At this point, trying physical device is a good idea.
« Last Edit: August 01, 2023, 10:54:49 pm by PCB.Wiz »
« Reply #13 on: August 02, 2023, 08:28:28 am »
Thanks for your interest.
Sadly I don't think I'm going to be able to get near a real device.  This is 16R4 and I cannot see any NOS of those just found some NOS on EBAY UK but I don't have a burner that will do them.
FYI
I'm trying to understand the behaviour of U13 on a Data I/O 701-2126 memory board (from a UniPak2B) but this is something I don't physical have and are pretty unobtainium... hence I'm trying to mod my 702-1650 board to behave as if it was a 701-2126.  It's possible that the power on state doesn't matter (because the register is written before being accessed) but I'm trying to narrow down the variables as testing will be hard.
« Last Edit: August 02, 2023, 08:41:28 am by NivagSwerdna »
Online PCB.Wiz
« Reply #14 on: August 02, 2023, 08:50:37 am »
FYI
Operationally, the power-up state is less important, it's mainly to ensure power-up is also safe until first write.
You can map a 16R4 design onto a 16V8, as you already see winCUPL do. Programmers for ATF16V8 should be more common.
Some programmers can take 16R4 fuses and map onto 16V8 - it says something like Device name:ATF16V8BQLas16R4
« Reply #15 on: August 05, 2023, 01:28:15 pm »
So I got my hands on a real device...
It doesn't seem to behave exactly how I had hoped...
I would expect the registered outputs 14, 15, 16, 17 to all be high because they are behind an inverting buffer and their registers would be expected to be LO... but hey... we have a non-beliverer... pin 15
Offline Stray Electron
« Reply #16 on: August 05, 2023, 02:50:19 pm »
   Wouldn't the Data I/O model 28 burn them with the right plug in module? I think one of the UniPak plug ins will handle those PALs. I bought a bunch of that stuff years ago with the plan to burn some PALs but I never got around to it.  Years ago I had a hoard of Data I/O programmers, manuals, plugins and other stuff but never used much of it and I don't know where it is now.
    IIRC Heathkit/Zenith used a lot of those simple PALs in their H-100/Z-100 computers and the manuals for the Heathkit version included all of the logic equations for the PALs.   Zenith made the same computer but it came already assembled but the Heathkit versions were kits so that gave you detailed assembly manuals with their equipment.
« Reply #17 on: August 05, 2023, 07:58:33 pm »
Wot no Logicpak.  I have a UniPak only.
« Last Edit: August 05, 2023, 08:00:53 pm by NivagSwerdna »
Online PCB.Wiz
« Reply #18 on: August 06, 2023, 06:06:50 am »
Yes, one seems out of step.
How did you obtain those plots ?
Is that test vectors running on a real programmed part ?
Maybe a CLK applied at Power-up ?
What does a part do, placed in a decoupled DIP socket, and CLK tied to GND, then power-up ?
« Reply #19 on: August 06, 2023, 02:44:16 pm »
My test rig is a homebrew chip tester that allows me to arbitrarily twiddle bits.
So I bent up in 1 and connected it with a bodge wire to pin 10 GND
14, 15 LO, 16 and 17 HI!
Then I twiddled the state of 13 to be HI
14, 15, 16, 17 HI
pin 13 should have no impact; it's not in the equations!
Then I made 12 also HI...
14, 15, 16, 17 HI
Very weird.  This would be much easier if you could imbed inline images in posts
« Last Edit: August 06, 2023, 02:46:00 pm by NivagSwerdna »
« Reply #20 on: August 07, 2023, 09:06:33 am »
I don't want to give up just yet... so thinking about why pin 13 is involved...  On the schematic pin 13 appears to be provided with a signal but the equations I got from JEDUTIL didn't mention pin 13...
So looking into the JED file and datasheet...
I never tried to read one of these before... I assume that each line of 32 bits reflects a fuse in this diagram so 48 actually is offset 1536
In the JED file...
L1536 11111111111111111111111111111111*
L1568 11111111111111111111111111111111*
L1600 00000000000000000000000000000000*
L1632 00000000000000000000000000000000*
L1664 00000000000000000000000000000000*
L1696 00000000000000000000000000000000*
L1728 00000000000000000000000000000000*
L1760 00000000000000000000000000000000*
L1792 00000000000000000000000000000000*
L1824 00000000000000000000000000000000*
L1856 00000000000000000000000000000000*
L1888 00000000000000000000000000000000*
L1920 00000000000000000000000000000000*
L1952 00000000000000000000000000000000*
L1984 00000000000000000000000000000000*
L2016 00000000000000000000000000000000*
At 1536 there are lots of 1's... and also the next row and then 0's to the end of the file.
If the intersection of every row with the 32 lines is a fuse does that mean don't burn fuses on line 48 and 49 and burn them all below?  Wouldn't that mean all the vertical lines get connected?
« Reply #21 on: August 07, 2023, 10:16:37 am »
So looking at the JED file... I see no ZEROs in column 26 or 27... so I think this pin 13 is unused and should have no effect.. but it does.
Online PCB.Wiz
« Reply #22 on: August 07, 2023, 08:26:24 pm »
Certainly strange.
Are you driving all pins with clean CMOS edges ?
I have seen CPLD’s get disturbed by touched floating pins with zero enabled logic.
My conclusion was the pin buffer was oscillating on the slow edges.
