Author Topic: [Solved] Unknown AC supply IC ASZBXA  (Read 1100 times)
Offline davorinTopic starter
    • LinkedIn Profile
« on: March 10, 2021, 01:32:34 pm »
Good afternoon (o;
Does somebody know what type of 8-SOIC IC this is in a WiFi power plug?
It is directly connected to a 3u3, 400V capacitor which is fed via a diode directly from the 230V AC main line...
Looks like a switcher device to get 5V directly from AC line...
Only marking I see is:  ASZBXA
« Last Edit: March 10, 2021, 02:07:07 pm by davorin »
Offline gamalot
  • Correct my English
    • Youtube
Re: Unknown AC supply IC ASZBXA
« Reply #1 on: March 10, 2021, 02:02:42 pm »
I'm a poet, I didn't even know it. |  https://youtube.com/@gamalot | https://github.com/gamalot
The following users thanked this post: davorin
    • LinkedIn Profile
« Reply #2 on: March 10, 2021, 02:06:52 pm »
Excellent, thanks :-)
Not my field those high voltages, except for old vacuum tube radios...but those are easier to repair/modify (o;
    • LinkedIn Profile
Re: [Solved] Unknown AC supply IC ASZBXA
« Reply #3 on: March 10, 2021, 03:25:25 pm »
Just in case someone is interested (o;
The IC is used in a Marmitek Power SE WiFI Plug...hop eI got the schematic right to continue swaping the WiFi module with an ESP8266 to run ESPHome (o;
https://github.com/richardklingler/marmitek/blob/main/pdf/power_se.pdf
