Author Topic: Unknown component  (Read 2832 times)
Offline atgeekTopic starter
Unknown component
« on: August 14, 2017, 05:52:33 pm »
I've found a 5V flip flop relay module which use just a 4 pin component for toggle the relay on and off, I've asked to the seller for a better front picture but there aren't any marking on it. Does anyone know what component or IC can it be?
Offline DBecker
Re: Unknown component
« Reply #1 on: August 14, 2017, 07:26:10 pm »
The relay modules typically use an optoisolator as the drive transistor.  But this is for a bistable relay module, using a standard relay.
My guess is that they are using a specialized chip developed for flashlights, with human-scale debouncing driving a flip-flop and output MOSFET.
« Last Edit: August 15, 2017, 01:55:45 pm by DBecker »
« Reply #2 on: August 15, 2017, 07:47:15 am »
Could it be this one? From the translation it should be a timer chip.
Offline zeqing
« Reply #3 on: August 15, 2017, 08:27:47 am »
a MOSFET, the "T" means "Trigger".. i think
Online Benta
« Reply #4 on: August 15, 2017, 09:01:12 am »
I'd say "T" means "toggle".
Offline DBecker
« Reply #5 on: August 15, 2017, 02:03:30 pm »
It's not the toaster timer chip shown.  The functionality is different, the pinout differs, and the chip on the module is able to drive the relay coil directly.
I'm still going with a power toggle used on LED flashlights, although I couldn't immediately find a matching chip.
« Last Edit: August 15, 2017, 05:41:13 pm by DBecker »
« Reply #6 on: August 15, 2017, 06:28:38 pm »
Would be really interesting know what kind of chip it is  :)
