Author Topic: Unknown EEprom help  (Read 2469 times)
Offline JerryLTopic starter
Unknown EEprom help
« on: April 26, 2019, 02:18:26 pm »
This chip is from the toner of a Lexmark MX321 printer toner.  The numbers I got from it are H1828553 and I am trying to read from it with an Arduino 2560 but haven't a clue where to start.  Anyone help I do know the pinout for the connection between the toner and printer and have it connected already but I do not know the commands yet.
Online coromonadalix
Re: Unknown EEprom help
« Reply #1 on: April 26, 2019, 02:31:54 pm »
you want to reset the toner ?
on alibaba search :   Toner-reset-chip-for-Lexmark
normally on 4 pins pcb toners chips  you have to find the +vcc and ground supply lines and with the 2 remaining pins  you have to fine the data lines, reset pins etc ... and fit your arduino accordingly
« Reply #2 on: April 27, 2019, 10:51:23 pm »
Got that done was just curious as what the chip was I know it is an eeprom and have the arduino 2560 connected now I need to lear the commands to read and write to the chip.  ANy help is gretaly appreciated
Offline PON
« Reply #3 on: January 03, 2020, 04:07:49 pm »
Hi.
Did U find what kind of chip is, and with what do U search? I'm also verry intersting about this eeprom
Offline kjr18
« Reply #4 on: January 04, 2020, 10:14:40 am »
Are you sure it's an eeprom? I skimmed through alibaba search and I see some toner reset chips boards with eeprom on it, some with two chips (one looks like a memory, second one like some uC), or even some that have two many_pin chips.
I guess that yours might be a microcontroller of some sort that has eeprom memory inside and communicates with i2c, or something like that.
The following users thanked this post: Kilrah
