First of all, Thank You guys for responding. Sorry, I haven't checked this in a few days.
Is mechanically retaining the USB C port an option? Ports usually fit snugly.
I'm not exactly sure what you are asking here? The usb ports we are testing have surface mount connections and through hole ground pins so the ports fit pretty rigidly. We have a hard plastic shell around the port to provide extra support. The issue I am seeing is where the cable plugs into the port, the cable itself, not the port, wiggles quite a bit. In my application, there is not a good way to support the cable if that is what you are asking.
- What is the part number?
- Have you looked inside the port with a microscope to ensure pins are clean of any possible flux residue?
We have tried a JAE PN: DX07S024WJ3R400 and Molex PN: 2047110001 and a handful of cables of different brands.
The ports were checked with a microscope and are clean on the inside. The cables seem to fully insert.
USB has a stirring and noise of the contacts, the noise level depends on the quality and cleanliness of the connector.
This is a good point. I have listed a couple of the part numbers we have tested above. They seem to be decent quality connectors. We have used many Molex connectors on other projects which have had no issues and our board house has used quite a few JAE components with no issues. We have verified that the cables and connectors are clean.
With USB C quickly becoming "THE" port of the future, I would expect it to be much more robust. I understand that, with moving, noise will be generated but I wouldn't expect it to completely drop the connection for long periods of time. I am seeing where the port loses connection then one must wiggle it again to remake the connection.
