Author Topic: USB-C power problem  (Read 1654 times)
Offline crgarciaTopic starter
  • Country: ar
USB-C power problem
« on: May 08, 2022, 05:50:38 pm »
Full project documentation/layout/schematics/etc: link
I had this design that worked fine with Micro USB (full schematics)
I now replaced it with an USB-C (full schematic)
When I connect an USB-C, the voltage drops almost to 2 volts (sorry for the img quality, rigol software stopped working)
1481365-2
The current seems to fluctuate between 20mA and 40mA (measured with a multimeter)
If I connect an external bench power supply to the 5V line, then it works fine, and current reaches around 80mA.
I am a bit lost on how to troubleshoot this...
Do you know what could be wrong?
Any ideas on what I can try out?
Thank you!
« Last Edit: May 08, 2022, 05:55:09 pm by crgarcia »
Offline NiHaoMike
    • Facebook Page
Re: USB-C power problem
« Reply #1 on: May 09, 2022, 02:39:26 am »
Connect shield and ground just as it was done for the micro USB. I also assume you ruled out a defective connector or defective cable?
BTC: 18813fu8LQEdDwH9YLM1ABed3XwCfeSeFi
The following users thanked this post: crgarcia
  • Country: ar
« Reply #2 on: May 10, 2022, 06:45:45 am »
Thank you very much evb149 and NiHaoMike!!
I found the problem:
The guilty one is the 50 Ohm resistor I added to the VBus (5V+) to limit inrush current. I placed it there because I have too much capacitance (> USB documented limitations)
Now I replaced the resistor by a 0Ohms and now everything works.
Thanks!
Offline pigrew
« Reply #3 on: May 10, 2022, 05:01:16 pm »
Thanks!
Yep... it gotta be between 1 and 10 uF.
My solution is usually putting a "soft-start" load switch (permanently turned on), which often has a side-benefit of integrating overcurrent protection.
Online jbb
« Reply #4 on: May 10, 2022, 09:53:24 pm »
You can also get switch ICs with over voltage protection, which is helpful.
One thing to keep an eye on is cable plugging - the cable has a little inductance and can form a resonant network with input caps. This can turn a 5V input into an 8V peak or more.
TVS diodes are of limited use there - you need around a 6V device, and it seems they can be relied on to reliably clamp at approximately 1.5x rating, ie 9V.
There are dire rumours around of non-compliant “USB” wall chargers that simply spit out 20V all the time.
