The reason I suggested such a complicated arrangement of hardware (ATmega32U4, MT8816AE, MAX3421E, 3.3V regulator, SPI level shifter between 32u4 and MAX3421E, a crystal for the 32u4, and a smattering of passives), is that I know the needed software already exists -- with the exception of mapping keypresses and releases to control the MT8816AE, and that looks very straightforward. You can even build an Arduino test rig and try it right now, using a cheap Pro Micro clone (just remember to select Arduino Leonardo in the Arduino environment!), an USB host shield, a 3.3V regulator (breadboard module), 3.3V-5V level shifters between the clone and the USB host shield, plus a MT8816AE. All those are available on fleabay (I checked), and in DIP versions, so you can breadboard it.
A 32-bit ARM microcontroller with USB host support would be electronically simpler (and cost much less in parts), as you'd probably only need some level shifters (they typically use 3.3V logic, and I believe the C64 uses 5V internally) to the MT8816AE and omit the USB host controller chip, but I believe the software side would need a lot more work, as the existing sources would not be usable as-is. (Unless, as Yansi said, there exists examples in the STM32 land and you use one; I would not know about those. I am only talking about the Arduino, and bare-metal/avr-gcc + avr-libc world here, without any hardware abstraction libraries. The Arduino libraries are surprisingly easy to modify to work on plain-metal avr-gcc, if bare-metal is your goal.)
Because of this, I believe that the ATmega32u4 -based solution is "better" in terms of overall value, especially as the target audience is one that probably values the easy customization/modification of the board. There is nothing stopping one (but the fear/probability of others cloning the board) from keeping the custom device programmable in the Arduino environment, for example.
(Of course, here we get into the business logic, which I fail. If the idea is to do this for fun and not for commercial gain, then the openness/ease of modification should be a win-win. If the idea is to make a small profit too, then.. well, I wouldn't know, my suggestion is utterly unlikely to yield that.)
