Seems I already blown my board, not sure what went wrong.
Everything worked, then I wanted to use the earth/mass connection of my probe to reduce noise. So I connected it to the mass of the board (mass of my 5V power supply)
It was OK, I wanted to reconnect it for a better connection and then it 'shorted' out somehow.
Now it only measures 1.67 ohm over C4.
The other (identical) side of the chip is still measuring fine.
Maybe connecting the ground of my power supply to my scope earth generated unexpected spikes....
Luckily it won't cost much to replace the chip. (if that is the problem, and C4 isn't broken)
