EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Using transformer with 10% higher input voltage
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Using transformer with 10% higher input voltage (Read 1144 times)
Jester
Frequent Contributor
Country:
on:
December 29, 2023, 07:57:52 pm »
Thoughts at using this transformer with 240V in at 220V terminal, and ~220V out at 200V terminal. Concern is over-excitation
Load is intermittent perhaps 20% duty cycle max. but will be near 1kVA at times.
Logged
Zero999
Super Contributor
Country:
0999
Re: Using transformer with 10% higher input voltage
Reply #1 on:
December 29, 2023, 08:07:53 pm »
It should be fine, especially given the low duty cycle.
Did you get it from Europe i.e. a 50Hz region? If so, then it's even better, since the slightly higher frequency will reduce the flux, reducing the chance of saturation.
Logged
BrokenYugo
Super Contributor
Country:
Reply #2 on:
December 29, 2023, 08:34:02 pm »
Japanese name and voltages make me think this is some sort of old boost transformer for using 220V (now 240) equipment on Japanese 200V power or vice versa, half of Japan is 50Hz so I wouldn't doubt it if it's happy on 240V 60Hz power. I'm no transformer expert but I would think checking the idle current at 240V would give a good idea. EDIT: idle power, not current.
Last Edit: December 30, 2023, 02:57:42 am by BrokenYugo
Logged
johansen
Super Contributor
Reply #3 on:
December 30, 2023, 02:18:20 am »
What are you worried about?
It will just warm up quicker.
Idle current is meaningless, you need a watt meter. or just weigh it, then put it in a well insulated box, leave it on for 1000 seconds (to make the math easier) and measure the temperature rise.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
