What the significance of using this over a single bridge rectifier for both taps as in the circuit which i have posted.
For example in your single bridge design if one of the capacitors will change its capacity due to many factors than you can end up with different +V and -V since they are charged in series-additionaly one of them can be overcharged to higher voltage than nominal if this capacity change will be higher
So, in simple mosfet driver design like this where I have two caps in series and ~24V accross them, I have additional resistors to balance capacitors voltage and keep its voltage at the same +/-V
But you have a few amps outputs there, so such simply balancing is not an option, so you'll probably have to pray and keep those caps at good condition, so that is one of the reasons I better like solution with two bridges and separate floating PSUs to form +/-V
