In my understanding, cheap SLA printers use LCDs as a mask, and they do damage them over time. Better SLA printers use DMDs. But as mentioned earlier in the thread, the limited lifetime of an LCD is probably not an issue with sporadic use in making PCBs. And the optics are much simpler with an LCD of course, which you can just use as a 1:1 mask sitting directly on the PCB.
To be honest, I struggle with the whole project a bit. It seems to aim at improving the one step in home-making PCBs which I think is in least need of improvement. What's wrong with laser-printing layouts on a transparent film? On the other hand, what about the messy etching, drilling/milling, aligning layers on double-sided boards, and obtaining some kind of connection between them?
For my projects, I don't consider home-making PCBs at all. I'd rather adjust to a one-week wait and get PCBs with much higher trace density, multiple layers, vias, silkscreen, soldermask... It would take major improvements in all steps of the home-made PCB process to get anywhere near the capabilities of the professional PCB houses, which I don't think will realistically happen.
