I use an array of eight 1W UV leds in my current home-made box. Works well. But I'm not doing anything incredibly challenging, the odd 10mil trace to squeeze in a tight spot is as fine as I care to bother with. However due to the fairly tight beam of a typical LED, even wide angle ones, my box has to be quite tall and in fact I have a double layer of diffusion between the leds and the platen (leds, then about 10cm above it is a glass sheet with a diffuser on each side, then about 10cm above that is the platen), otherwise there would be bad hot spots in the exposure area.
I have them arranged (over a slightly larger than A4 area) in a 3:2:3 pattern.
I've seen others use the LED strip you describe, I think people have said it works well for them, but again I'd be concerned about hot-spots with a short distance between platen and leds.
