It's very difficult to fully troubleshoot the problem because it's likely inside an IC - the '518 or MCU that has crosstalk.
In the pics I can see right-most digit has "C" segment stuck on, is that the only malfunction in the pics?
I would scope that pin on the VFD to see if the '518's output driver has a problem like a weird weak voltage. But it is odd that segment prefers that digit. I was thinking of DRAM/SRAM stuck bits.
If you are pulling the VFD, I suggest putting a soft piece of tubing over the nipple, it is extremely fragile and easy to bang. Or scotch tape something maybe.
Getting the shields off does take a bit of extra heat, as I mentioned my technique is to use a soldering iron heating on the pin topside, and vac desolder on the other side. A two-handed affair. The VFD holes on the PCB are large though.
Some notes I found on the '518 protocol, to help you out if you are still digging:
For 53131A
The protocol is similar to SPI. It is clocked at ~1 MHz, with 4 byte word bursts at about 1 kHz rate. It is 5 V logic.
The lines and their SPI equivalents are:
VFDSCLK - Clock, data sampling on rising edge
VFDSOUT - Data, from MCU to display
VFDSIN - Data, from display to MCU, 32 bit shift register
VFDSEN - Enable, active high, inverted compared to a SPI /SS
VFDSCLK:
____ _ _ _ _ _ _____
\_/ \_/ \_/ ... _/ \_/ \_/
VFDSOUT:
________________ _______________
\___X___X___ ... ___X___X___/
VFDSEN:
__/ ... \___
Bit: (MSB first)
0 1 2 ... 29 30 31
Every ~976 us (~1024 Hz), there is a 32 bit word, with bits clocked at ~934 kHz. After the first 16 bits, the clock makes a small pause of about 0.5 bit cycle.
Each 32 bit word enables one gate (character position) and any combination of segments for that position. The first 12 bits are gate enablers, the first/highest bit enabling the leftmost/most significant character. The segments are 14 bits for the segments of the digit/character display, 3 bits for the separator segments for ".",
",", ":" and ";" and 1 bit for the text label under each character. The rightmost character is special; instead of separators the bits enable the "u" (mu) and "s" unit indicators and the "Gate" text label, and it has two extra bits for the "M" and "Hz" unit indicators.
A frame has 16 words - 1 for each of the 12 characters, and 4 extra that can be highlighted, x0-x3 below. The frame rate is ~1024 / 16 = ~64 Hz.
Below data is shown as big endian, first byte leftmost, and with first bit on SPI as most significant.
Bits:
0xfff00000 - gate enablers (character position)
0x0000fcff - 14 segment character
0x00070000 - separators, on rightmost position "u", "s" and "Gate"
0x00080000 - text label
0x00000300 - on rightmost position units "M", "Hz"
Examples:
Text: "FREQUENCY 1 "; Labels: "Freq", "Ch1"
1000CC8C # char 8 "Q"
100000 # char 0 empty
2000C087 # char 9 "E"
202040 # char 1 "1"
4008888F # char 10 "R", label: "Freq"
400000 # char 2 empty (space)
80008087 # char 11 "F"
802030 # char 3 "Y"
80000000 # x3 - no highlighting
108C084 # char 4 "C", label: "Ch1"
80000000 # x2 - no highlighting
2008C2C # char 5 "N"
80000000 # x1 - no highlighting
400C087 # char 6 "E"
80000000 # x0 - no highlighting
800C40C # char 7 "U"
When a character is blinking, it changes between being normally displayed and being highlighted. The character is powered an extra time per frame using word x0-x3 which makes it brighter. The flashing, changing between the character and empty, is done in the normal word for that character. Only the 14 segments of the character seems to be
flashing and highlighted, not the indicators or the text labels.
As there are only 4 words x0-x3, only 4 characters can be highlighted using this mechanism, and it seems also never more than 4 characters are highlighted and blinking.
"LIM TEST: OFF", where "OFF" is highlighted and blinking
10000000 # char 8 space
108087 # char 0 "F"
2000843C # char 9 "M"
208087 # char 1 "F"
400860C0 # char 10 "I", label: "Freq"
40C48C # char 2 "O"
8000C004 # char 11 "L"
800000 # char 3 space
80000000 # x3 - empty, no highlight
10B20C0 # char 4 "T", separator ":", label "Ch1"
108087 # x2 - highlight char 0 "F"
20044A1 # char 5 "S"
208087 # x1 - highlight char 1 "F"
40C48C # x0 - highlight char 2 "O"
80020C0 # char 7 "T
100000 # char 0 empty ***
200000 # char 1 empty ***
400000 # char 2 empty ***
80020C0 # char 7 "T
