Hello,
I am currently designing a lab amplifier for my signal generator and other general signals that I would like to amplify or buffer.
Given that I am using ADA4870 amplifiers in parallel, all with fixed gain, I believe it would be beneficial to incorporate a variable attenuation option at the input. This would allow for a wider range of input voltages.
I have experimented with MOSFETs and BJTs as attenuators, but they tend to exhibit high capacitance. I also tried using an optoresistor, which I constructed with a photoresistor and a super bright LED. While this solution has low capacitance and avoids the Miller effect, it lacks linearity.
I am seeking advice on the best approach to achieve variable attenuation for input frequencies up to 15 MHz. Minimizing distortion is crucial, as I need to maintain the integrity of fast-rising square waves without excessive rounding of the corners.
Any suggestions or tips would be greatly appreciated.
Thank you.
