Hi guys,
I've been working on a project and have a question on a particular section of the project.
this section I've redesigned in hopes of producing a smaller circuit and better performance in terms of Power Out.
I'll refer to the attached schematic drawing.
The basic idea is that U12 is a DAC which provides a reference voltage to control the current flowing through Q2. U2 is the current sense amplifier which provides the current feedback for the U11.1 op amp controlling the current from PWR_IN to PWR_OUT. This is intended to control the load being applied to an external generator. The small section of the right is intended to ensure that if the power from the generator is not entirely used by the system connected to PWR_OUT, then Q1 will conduct any excess current from the generator.
Would this configuration do a fairly reasonable job at controlling the current flow of the circuit? Is there anything obviously wrong with this idea?
