Author Topic: vertical right angle slider switch array  (Read 1892 times)
Offline stern0m1Topic starter
« on: June 24, 2018, 03:42:17 am »
Im looking for a switch like this, but an array of 4. 1 piece with 4 switches
Vertical right angle slider.
Anyone come across something?
Thanks
Offline ebastler
Re: vertical right angle slider switch array
« Reply #1 on: June 24, 2018, 07:13:48 am »
Does it have to be DPST SPDT? If a simple on/off switch is sufficient, angled DIP switches are widely available. (But may also be a bit smaller than what you had in mind?)
Edit: Fixed the mixed-up switch designation... :-[
« Last Edit: June 24, 2018, 04:36:59 pm by ebastler »
« Reply #2 on: June 24, 2018, 04:09:09 pm »
 I need an on on switch. A switch with two positions each position connects 1 pin to a different one.
Thanks
Offline rdl
« Reply #3 on: June 24, 2018, 04:23:23 pm »
Switches like the one in the picture exist and should be easy to find, but an array of four may be impossible to find outside of custom made. What do you expect to gain with an array vs. four single switches side by side?
« Reply #4 on: June 24, 2018, 04:35:22 pm »
Price. The cheapest I found for a single switch was 65 cents us. The only switch I found at all this style was from http://www.dailywell.com.tw/
If you know of others please tell me.
Thanks
Offline rdl
« Reply #5 on: June 26, 2018, 10:05:21 am »
Apparently those vertical style switches are pretty expensive, $3-$4. You might consider using the cheaper type and mounting them on a small piece of pcb attached vertically to the main pcb. I have seen this done in commercial products with 7 segment displays.
Some ideas maybe here:
https://www.eevblog.com/forum/projects/mount-pcbs-together-in-a-90-angle/
