Author Topic: Voltage source switching with FETs  (Read 1358 times)
Offline 3cdbTopic starter
« on: February 23, 2023, 11:51:36 pm »
Hi all!
I figured I'd ask on this forum about possible fixes/recommendations/ideas for what I'm trying to do.
I've been trying to make a small circuit which switches its output either from a regulated +5Vdc source, or from a +4.2Vdc source (from an 18650 cell).
The idea is that when the 5V is connected, the output is 5V but when the 5V is disconnected, the output is 4.2V instead.
I have come up with a circuit so far, but after building and testing, it does not seem to work  :-//
I have attached the circuit I have come up with so far.
Anyone have any ideas of what I can do?
Offline Kim Christensen
Re: Voltage source switching with FETs
« Reply #1 on: February 24, 2023, 12:52:52 am »
Maybe have a look at this page to see exactly how complex you need to go. (I think a version of example 2 will work for you)
Offline Peabody
« Reply #2 on: February 24, 2023, 04:21:51 am »
This circuit should work.  If both supplies are connected, the one with the higher voltage will be selected.
Offline inse
« Reply #3 on: February 24, 2023, 07:49:35 am »
Two Schottky diodes would not do the job?
Offline Peabody
« Reply #4 on: February 24, 2023, 03:24:44 pm »
Yes, two diodes would certainly work, but then you have a 0.3V voltage drop in the battery line which reduces the effective battery life.  The mosfet replaces the diode in that line, and the drop is very low when it's turned on.
