The capacitor in feedback is not critical. It just sets the upper bandwidth limit for the amplified part. Anything from 100 pF to 1 µF would be OK - possibly less in a high impedance setup. A normal cap. should be OK, as long as leakage is not extremely high. The position across R6 is not helping much, the critical part is the high impedance from the trimmer. The right place is from the inv. Input to the output.
As for the layout at the reference, symmetric would be preferred, even if this would mean having an extra blind connection at the other pin. It's also better to have the 2 lines close together, not separated as in the current layout. Another option would be to make the bottom a complete ring around the 4 Pins to reduce thermal gradients.
If there is place is might also help to have something to fix a cover to the board, as to prevent turbulent airflow around the OP.
