There is something magic in these inductors and resonances.
In 90's I was working for a small company and once upon a time a chess master came to our office. He used to travel around the country with the purpose to perform simultaneous game show. He was thinking about how to improve the show. So he asked if we could design a hi-tech chess board with a computer interface. After some thinking, I came to the conclusion that the only reliable way would be to use the RFID method. Then I did some research and found a nice RFID tag from Temic, in the form of tiny glass tube. That's easy to plant that tag in a chessman. But I was not sure about actual availability, lead time and cost for that part and finally decided to design everything from scratch as that likely will be faster. And I succeeded. A working prototype was built in two months (see the attached images).
Two surprises were encountered in the process. In RFID, the energy is wirelessly transferred between two resonant tanks. That's obvious, the Q-factor in the transmitter tank depends on energy consumption by the receiver tank. The more energy is consumed, the less the Q factor is (and therefore, the less is the voltage/current amplitude across the tx resonant circuit). But it not always so simple. In reality, when the rx tank is almost short circuited (max. current consumption), it effectively becomes aperiodic and disturbs the tx tank less. That results in increased AC voltage across the capacitor of the tx tank, not decreased.
Soon after I'd found a better job and left the company. Much later I learned that the guy who was assigned to that project had a problem to reproduce my prototype. I used a high frequency space-grade capacitors (from my stockpile), while he tried to use cheap random caps, arguing that the design is actually not of HF (100 kHz). But that's actually not a surprise that the components quality matters.
To the OP: The person who's most capable to solve your project problems is you. Everyone else is less aware of your particularities and therefore is much less capable. If you can't sort this out then nobody can. It's as simple as that.
