Author Topic: Weird LDO behaviour  (Read 1459 times)
Offline escapekitTopic starter
Weird LDO behaviour
« on: August 17, 2020, 11:11:29 am »
I am designing a PCB and I have a problem with the LDO, the voltage mesured in the output should be 5v but it is over 7v.
I have several PCB's i got assembled from JLC and all of them have the same problem, one is outputting 7,02v, another 7,26v and the rest are somwhere in between.
This is the schematic for the power supply part of the PCB
1048646-0
I used an AO4407A (P-channel Mosfet) to protect from reverse polarity, and an AMS1117-5.0 to lower the 12v VCC into 5v to power an ATmega 2560, optoisolators, mosfets, a couple of ULN2003A, a YX5200 mp3 player IC, an oled display and a couple more little things.
I don't know if I did something wrong or the LDOs are defective.
This is the pcb layout:
1048650-1
Any help would be really appreciated.
Offline mzzj
Re: Weird LDO behaviour
« Reply #1 on: August 17, 2020, 11:25:43 am »
From datasheet: minimum load 10mA. Did you happen to test the boards without load on the 5v supply?
« Reply #2 on: August 17, 2020, 11:40:03 am »
Yes, that must be it, I tried plugging in the OLED display and it works fine.  |O
Offline mzzj
« Reply #3 on: August 17, 2020, 07:36:52 pm »
This is a really common trap with low dropout regulators and negative 79xx type regulators.  ;)
Offline perieanuo
« Reply #4 on: August 18, 2020, 11:13:05 am »
that should be made sticky for every beginner in electronics.most of us saw the same thing at one time :)
Offline uer166
« Reply #5 on: August 20, 2020, 04:26:48 am »
Is there a decent modern jellybean regulator similar to the 1117 types that does not have a minimum load, stable with ceramics, 0.5A+ and such? I'm not sure why, but the most available LDOs/linear regulators seem to be relics with weird requirements like minimum load.
Offline iteratee
  • Computer Engineer
« Reply #6 on: August 20, 2020, 06:53:46 am »
Zero load floating linear reg? Isn't that like trying to charge a cap to 5V with a series 5V zener? If zener leakage > cap leakage it's hopeless.
