yeah a DC block I noticed some of these things have a small DC signal thats messing with my op amp stuff. But that is low power. For higher power I did not come across a use but when I was shopping for boxes I thought why not
I made like a composite op amp that was driving me insane all day with bizzare signals, I finally realized the function gen 'AC' mode had a 30mV offset. When I manually put it into offset mode and zero it out, the op amps were fine. I thought it was some kind of bull shit with ground planes (like weird slopes in negative cycle). This thing would work, to a certain power level, then it would 'latch' into a waveform that the negative portion of cycle was turning into a linear ramp line between like 65-80% of its duration.
Compensation, input problems, idk.. turned out that the small offset was making it crazy. Not clipping. like if you erased a portion of the bottom sine wave after the lowest voltage point, and drew a strait line, then turned it sinusoidal again. and you need to reset signal to basically 0 before it went away. partial AC latchup failure or something
because I had it wired on strip board with a bunch of wires to a star ground. I thought wow do i really need a ground plane for this low frequency? (lots of decoupling capacitors were there already). Guess not, it was just the offset voltage on the input signal.
probobly should take a look inside the FG to see if maybe there is a bad cap or what (tektronix cfg280 or something, cheap unit.. but when you put a noctua fan in it, its very quiet and a pleasure to use for prototypes).
I got the strip breaker tool (4mm drill bit in a starrett collet) and the keystone rivet-in threaded standoffs, and it turns out strip board is a pleasure to work on. Also bought an assortment of teflon solid wire in alot of different bright colors (22 awg?). With the big ones there is no problem to mount a heat sink on it. Highly recommend getting the large strip board segments (like 6x4 inches at least). Just put standoffs in it offset from your PCB vise and its really handy. way more fun then simulation. I just need to get the smallest hand drill they have for breaking strips with the drill bit, bit of a pain manually.
