Author Topic: What a hell is this?  (Read 7767 times)
Offline justin66Topic starter
« on: July 28, 2015, 11:53:38 am »
ok first of all i thought im gonna make pcb myself but i dont have a drill so im stuch with this board. i have built the amplifier based on lm3886t IC and its not working i have few questions
1 how do i diagnose the problem given in mind i only have a multimeter
2 im pretty sure i did everything right coz its not so hard to build and follow the traces could circuit be wrong?
3 what a hell are those unnecessary traces or whatever you wanna call it in picture 3 how do i remove them?
4 i give up i will use a company who make pcb boards what should i give them as a pcb design? how does it work? they ask me to convert eagle format to Gerber RS-274x how do i do that and how do i determine the size of the pcb?
pcb file from eagle
http://www.failai.lt/volslhqxc3xz/SP0001.brd
images
« Last Edit: July 28, 2015, 12:03:34 pm by justin66 »
Offline McBryce
Re: What a hell is this?
« Reply #1 on: July 28, 2015, 12:05:03 pm »
Hi Justin,
          I can't answer everything here, but here's a few answers:
1 - Difficult. I'd start by at least confirming voltages and currents such as the supply voltage to the LM3886 IC.
3 - Those dotted lines are a polyline, usually used to define the borders of a ground plane. Try right-clicking on one, then choose rename (choose all segments) and re-name it to GND. This should fill the empty space with a ground plane. The smaller inner polyline seems to be defining a "keep-out" area.
4 - There's a dimension tool in Eagle (fourth button from the bottom on the left) which you can use to measure the PCB.
A few further questions on getting it working / diagnosing: What are you powering the PCB with? Have you a proper split rail supply for it? How many amps are the two rails pulling? What signal are you injecting into the amp to test it?
A further tip: The LM3886 has that massive tab on the back for a reason - It gets hot, very hot when working. Strap a big heatsink to it, otherwise it won't be working for very long when you do get it up and running.
McBryce.
« Last Edit: July 28, 2015, 12:10:17 pm by McBryce »
Offline rs20
« Reply #2 on: July 28, 2015, 12:06:44 pm »
1, 2. What's the problem? "It's not working" isn't enough information.
3. Are those traces, or are they DRC error markers showing you that your traces are too close to the edge of the board? Did they appear only after you did a DRC?
4. http://lmgtfy.com/?q=eagle+export+gerber
« Reply #3 on: July 28, 2015, 12:18:12 pm »
Hi Justin,
McBryce.
a big THANKS for reply im powering it either with switching 50w 12v power supply or with a non switching  transformer like this 23.7v DC kind of
http://www.part.lt/img/7bb34f037aa75e7ba46aadde9a851da2543.jpg
« Reply #4 on: July 28, 2015, 12:24:50 pm »
2 yes its not working and i dont know why and it has v- v+ and gnd witch one of those should i use?
3 i have no idea i have downloaded this project files and i have no idea about whats happening im a noob when it comes to pcb designing and understanding stuff. can you help? this is the site i have download files http://andy-progetti.com/small-and-high-performance-audio-power-amplifier-lm3886/#comment-98
Offline McBryce
« Reply #5 on: July 28, 2015, 12:27:56 pm »
??  :o But it needs a split rail +V / 0V / -V to work? Why would you think that it would work with a 12V single rail supply? Where are you even connecting the 12V to?
McBryce.
« Reply #6 on: July 28, 2015, 12:29:16 pm »
oh fu** im noob  :-BROKE
Offline McBryce
« Reply #7 on: July 28, 2015, 12:32:05 pm »
Let's take a step back. What do you want to amplify? Can it be done with a single rail supply amplifier? If so, check out some single rail designs.
McBryce.
« Reply #8 on: July 28, 2015, 12:32:16 pm »
McBryce.
should i build one of thiese?
some how
http://farm6.static.flickr.com/5063/5619660342_6dc9a5697e_b.jpg
« Reply #9 on: July 28, 2015, 12:39:25 pm »
McBryce.
ok i want power two 8ohm woofers connected in paralel each one is 300 chinise watts and maybe 60-120w rms as for now im powering it with tda 2050 but if i turn volume more than 50% it distorts like crazy so i figured i need more powaaa. and i found decent chip amp that can do it for the most part.
http://www.part.lt/img/3d29a568a92172347997ba5fa6fa2849702.jpg
Offline McBryce
« Reply #10 on: July 28, 2015, 12:40:03 pm »
some how
No definitely not. The proper way to do it is with a transformer that has a centre tap like this: http://www.homemadecircuits.com/wp-content/uploads/2014/08/dual-voltage-power-supply.jpg
It doesn't have to be that complicated, this example is for variable voltage output, you can use fixed value regulators to reduce the part count.
McBryce.
« Reply #11 on: July 28, 2015, 12:47:51 pm »
but can i fake the ground just to test the circuit somehow?
Offline McBryce
« Reply #12 on: July 28, 2015, 12:53:19 pm »
Yes, several ways:
1 - Use two isolated PSUs with the positive of one connected to the negative of the other.
2 - Use a PSU with twice the voltage you need and create a virtual ground with a resistor divider.
McBryce.
« Reply #13 on: July 28, 2015, 01:04:12 pm »
a big thanks mate
Online Zero999
  • 0999
« Reply #14 on: July 28, 2015, 02:35:45 pm »
Figure 3 on page 6 of the datasheet shows a configuration which will work on a single supply rail. Note how a potential divider followed by an emitter follower is connected to pin 7.
http://www.ti.com/lit/ds/symlink/lm3886.pdf
