Looks awfully like a Molex Picoblade.
The body of the connector does look like the Molex Picoblade but..... the front face of the connector does not. The molex connector have one row of pin holes on the front of the connector. See attached picture.
The pictures I posted have what looks like two rows of pin holes. One row is bigger and looks like (also in same position) the molex connector's. But they are blank. I.e. there is only indentations in the palstic but no pin holes. The actual pin holes is the smaller row on the bottom. You can see the crimp terminals in this position/row when you look at the picture where the connector is turned around.
I should have measured the connector dimensions. This would have being a good clue. I think this is 1.27mm spacing.
I will do a post with dimensions when I am at home. I hope this post will still have some life in it by that time.
