Author Topic: What is this plastic dingus called?  (Read 1980 times)
Offline Alex EisenhutTopic starter
  • Place text here.
« on: June 17, 2020, 03:49:06 am »
The clip that holds the tiny circular helitrim pots on the PCB?
These pots are about 6mm in diameter. Attached is a picture of two of these little guys on a very dusty 1S2.
I've searched for holder, clip, and pcb mount. Nothing.
I'm also asking on Tekscopes but it's so much easier to attach pictures here...  8)
Offline andy3055
Re: What is this plastic dingus called?
« Reply #1 on: June 17, 2020, 06:02:57 am »
I believe it is listed in the service manual as "HOLDER, variable resistor." Page: 9-10. Several other places has the same ref.
The following users thanked this post: Alex Eisenhut
Offline mikerj
« Reply #2 on: June 17, 2020, 10:48:05 am »
Probably a custom part.  You might find something suitable in the automotive sector, this kind of thing is often used for clipping pipes etc. to metal panels.
Offline MLXXXp
« Reply #3 on: June 17, 2020, 06:11:13 pm »
Could you get away with a small cable tie holder and tie?
https://www.digikey.ca/en/products/detail/panduit-corp/TM1A-M/4569096
Offline DaJMasta
    • medpants.com
« Reply #4 on: June 17, 2020, 06:33:57 pm »
Looks like it was probably designed for the pots in question, and I don't know of availability now.  A prime candidate for 3d printing, but as mentioned a replacement with similar functionality but different looks probably isn't hard to come by.
  • Place text here.
« Reply #5 on: June 17, 2020, 06:57:16 pm »
I think I might just give up for now, it is surely not that important... Just irritating.
Offline max_torque
    • bitdynamics
« Reply #6 on: June 17, 2020, 07:06:40 pm »
it could be a repuprosed pipe clip!
You can get plastic pipe clips for things like car brake pipes, which are around 1/4" / 6mm in diameter?
