Connecting the primaries in series will make 2x 6V on the secondary side that can be used in parallel, individually or as 12V center tap.
Edit: thinking a bit more, with two switches commutating the primaries and secondaries in series or parallel on each side, can produce 6V, 2x 6V, 12v, 2x12 or 24v AC. May be useful to make a bench power supply.
