Author Topic: When does temperature coefficient matter?  (Read 20204 times)
Offline (In)SanityTopic starter
« on: January 21, 2013, 02:51:29 am »
So I've been doing a whole lot of temperature coefficient checking lately due to a questionable batch of resistors.   Well it got me thinking about why am I so concerned, and when does it really matter ?
I started to compile a list of areas where low quality parts might not make a difference.   I encourage feedback on this list and would love for more items to add to the list.
In the case of a resistor,  when does temperature coefficient not really mater ?
1.   For a pull up resistor.
2.   For a pull down resistor.
3.   For a current limit on a simple charge circuit.
4.   When used with a basic audio amp circuit.
5.   When used as a bias or current limit on a switching circuit.  Such as BJT drive or FET limit.
6.   When used as a half divider,  assuming both resistors drift equally and in the same direction (Crossed this one off for being impractical)
7.   For an LED voltage drop resistor.
When does temperature coefficient matter ?
1.   In a divider that's not doing exactly half.
2.   In an op-amp circuit where the resistor is controlling gain and it needs to be accurate.
3.   In a current sense device where accuracy matters.
4.   In a DAC type circuit R2R ladder,  etc.  This really goes right back to #1.
Perhaps I'm just tired while writing this,  but I'm finding it hard to think of cases where temperature coefficient of a resistor counts to a large degree outside of unequal dividers,current sense circuits and precision amps.   Situations where an exact current needs to be drawn from a divider might also be one of them.   Feedback loops really fall back in to that divider area (#1).
I think it's beneficial for everyone to understand where they should and shouldn't skimp on parts.   I'm very confident others will have a ton of items that don't fall in to #1,2 or 3.
Thanks,
Jeff
Edit:
Not sure what I was thinking.   If the TC of the resistors in a divider are all equal and the sign of the TC is equal for all of them then in theory the divider won't produce error caused by the TC.   This is not at all likely to occur.
« Last Edit: January 21, 2013, 04:03:56 am by (In)Sanity »
Offline Jay_Diddy_B
Re: When does temperature coefficient matter?
« Reply #1 on: January 21, 2013, 03:01:57 am »
Hi Jeff,
There is nothing really magic about a divider whose division is ration is 0.5. Tempco still matters in this case.
The reason is that tempco is stated without reference to a the sign. Two 100 ppm resistor can drift with temperature in opposite directions.
The manufacturers aim to get a tempco of zero mixing various components. If the mixture was very uniform then all the resistors would have a low temperature coefficient. If the mixture is not uniform there will be a spread in tempco between the parts.
The other consideration is operating temperature. If the unit does not experience wide temperature variation, it may not be so important.
Jay_Diddy_B
« Reply #2 on: January 21, 2013, 03:05:59 am »
Hi Jeff,
Jay_Diddy_B
True,  I didn't really think about real world manufacturing processes.   So we can cross that one off the list for anything outside of hobby projects.
Jeff
alm
  • Guest
« Reply #3 on: January 21, 2013, 03:06:23 am »
Any differential circuit, since CMRR directly depends matching the gain for the positive and negative part. TC tracking is more important in this (and many other) cases, but how do you ensure tracking if they only specify a max TC? You also need to make sure they're at the same temperature.
A bad TC can even introduce distortion in some amplifier designs: more current flows at the peaks of a sine, this might heat a resistor, change its value, affecting the gain. This produces harmonic distortion.
« Reply #4 on: January 21, 2013, 03:10:08 am »
Alm,  yah that was my #4 on the first list.  "Basic Audio amp".   Without a doubt for anything of quality it needs to have good TC.
Thanks,
Jeff
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #5 on: January 21, 2013, 04:04:21 am »
imho... no buddy (and i swear :P)... there is only one simple answer to this, it will answer all of your questions, we can make an infinite length of talk but it will comes down to one simple thing.... tempco matters when you are doing precision instrument. how precise? that is you to define it. precise i mean accurate, low drift, repeatable etc anything you can find in the book. cheers.
« Reply #6 on: January 21, 2013, 04:14:50 am »
Yes,  but where exactly in that high precision circuit ?   Are you going to use a 0.5ppm TC resistor to drive a status LED?   I think it goes without saying that dividers (in any form) should use high quality low TC components,  I also think they should be of the same sign and perhaps depending on the situation be the opposite of other components in the design.   For example countering the negative drift of silicon with positive drift from another component..etc.   Temperature compensation is another area I would love to touch upon at some point.
Perhaps it would be easier to list areas where TC doesn't really matter.
Thanks,
Jeff
Offline c4757p
  • adieu
« Reply #7 on: January 21, 2013, 04:18:29 am »
In my opinion, these sort of questions are symptomatic of the wrong approach to engineering. Does it matter? Yes. Everything always matters. The question is "how much?". Before you design your circuit you should come up with a plan for its capabilities and tolerances, and if you're wondering if the tempco of something is relevant, you need to calculate how much it affects the circuit, and whether that puts you inside or outside your specifications. A quick order-of-magnitude calculation in your head will suffice when you have a huge margin, like pullup resistors.
Binary "does it matter" questions lead to fantastic overengineering where it's not needed, limited by blind underengineering in the rest of the circuit.
« Reply #8 on: January 21, 2013, 04:27:00 am »
For the most part I already know the areas where it matters and where it doesn't.   I thought it might be an interesting exercise to narrow down and list out where it "really matters".   If your new to the game you might ask questions such as does the TC of a pullup resistor really matter ?   Well,  maybe it does.  Perhaps it will decrease in resistance which causes heating in another component which sits next to something else and causes drift.    So your correct,  it always matters :)
Offline c4757p
  • adieu
« Reply #9 on: January 21, 2013, 04:31:25 am »
I think a better way to phrase it would be "When should temperature coefficient matter?", i.e., if your design requires precision low-tempco pullup resistors, don't buy precision low-tempco resistors - redesign your circuit. I'm sure somebody would find a way to make a circuit where it matters and be damn confused because he was told it doesn't  :)
« Reply #10 on: January 21, 2013, 04:42:44 am »
Good point,  so perhaps this is a dead thread.   I'm always looking for those weird exceptions where two 1000ppm resistors can form a highly precise divider that doesn't drift at all.   Too much theory and not enough practice.   I just starting to touch on temperature compensation on some of the projects I'm working on.  My problem is I always want to just fix it in software :)
Thanks,
Jeff
Offline ftransform
« Reply #11 on: January 21, 2013, 05:38:27 am »
I am developing a negative association to resistor after spending so much time with those resistors. It's like eating Thanksgiving turkey for 5 days in a row.
We must find another mostly overlooked passive component property to nitpick now, at least for a while. Any suggestions?
Perhaps inductor tempco? noise? Microphonics studies? Giving up and playing with a arduino?
I feel like this forum recently went through a really STRONG ESD phase, I don't want to resurrect that one quite yet.
« Last Edit: January 21, 2013, 05:40:03 am by ftransform »
alm
  • Guest
« Reply #12 on: January 21, 2013, 05:50:39 am »
You can spend much more time on capacitors. All kinds of fun parasitic effects to talk about: ESR, ESL, voltage coefficient, dielectric absorption, microphonics, aging and even tempco ;).
Transformers and inductors could be another fun topic, but is mostly limited to power supplies these days.
« Reply #13 on: January 21, 2013, 05:57:19 am »
Let's not forget leakage current :)
Great now I'll be messing with the LCR meter and my little environmental test chamber.
Actually I just tested a  Fairchild LM78L05.   74ppm/C or 0.37mv/C drift.    I think temperature compensation is a better subject,  it's kind of cops and robbers.   So in theory I should be able to get this 78L05 down to very little drift with the correct reverse TC components adding in to the mix.   That of course opens up the can of worms called linearity.   But it's all fun.
Jeff
Offline ftransform
« Reply #14 on: January 21, 2013, 06:27:29 am »
Oh that's an interesting idea I wonder if you can use a resistor to fix that drift. That would actually be pretty neat.
I wonder what photonicinduction thinks of this topic.
Offline PA4TIM
« Reply #15 on: January 21, 2013, 08:46:39 am »
On Circuits online we gad a topic frim someone who tried to get the best out of a 7805 and he came pretty far ( not like a Vref but still much further as I had expected)
Capacitors are fun, inductors even more. They have tempco, harmonic distortion, Q, saturation, current cooficient, eddy currents, voltage coofficient, skineffect, Ohms serie resistans, formfactor, distributed "capacitance" ( real capacitance and Phase delay) , parallel resistance. Are very influenced by the surrounding materials, selfresonant ( unwanted or just planned) and for most, very hard to measure.
Offline chickenHeadKnob
« Reply #16 on: January 21, 2013, 09:06:54 am »
Amen brother, actually there is a deeper issue with this forum insidiously inducing volt-nuttery in hapless bystanders such as myself. I thought I was immune but I find myself cruising ebay for precision  references and bench DMM's more and more. What the hell happened to me! it is like a crystal meth addiction. Friends don't let friends volt-nut.
Offline PA4TIM
« Reply #17 on: January 21, 2013, 09:11:10 am »
It can be worse, i'm a time-nut too.
Besides volt and components nut.
Offline hans
« Reply #18 on: January 21, 2013, 09:15:01 am »
A little sidejump to the original question. The answer is pretty simple.
Compute the gain formula for your 'blackbox' analog circuit. Have an input, have an output, and it's relationship.
All values from components in that formula have a temperature coefficient. Some have bigger influence than others. Therefore, if you requirement is 0.1%, a influence of 1/10000 drift doesn't matter, but 1/500 drift does matter.
With temperature coefficients, operating range, and initial accuracy + trimming/compensation, you can work out how precise your system is.
Good luck writing a shitload of math down  :-X
Offline Harvs
« Reply #19 on: January 21, 2013, 10:44:33 am »
There's a pretty good explanation of an error budget in the Chap 7 precision circuit, of The Art of Electronics which most people seem to have.
You can pretty much wrap most of these discussions up into that type of analysis.
  • Country: my
« Reply #20 on: January 21, 2013, 12:11:21 pm »
i want to trigger (output hi) the comparator at slightly +ve voltage. 0.1, 0.2,0.3v doesnt matter as long as it doesnt trigger at ambiguosly 0V, so i make a voltage divider something like 100K+1K. tempco? doesnt matter!
configuration usually found or same as in...
doesnt matter! please note i've striked the accuracy part of the quote.
where in one situation it doesnt matter, in another situation, it does matter. its quite difficult to classify. i agree though some app, are almost certainly doesnt matter such as digital pull-up, current limit protection, lighting up LED, capacitor drain etc. the bottom line is, as long as you are not going to specify its accuracy, it doesnt matter.
Offline ftransform
« Reply #21 on: January 21, 2013, 10:04:44 pm »
at least you don't collect human ears  :-+
« Reply #22 on: January 21, 2013, 11:23:42 pm »
I second the Amen.   While it's good to be precise,  perhaps being productive is slightly more important.
Maybe I should have titled this topic as "When can I get away with using low grade crap without the boss noticing?".    I also completely botched the whole divider statements.   I was too focused on resistors in this case that basic logic escaped me.    Two resistors equal temp co,  same direction...yah those will make a great divider.   Too bad you can't use that concept in production.
Offline krenzo
« Reply #23 on: January 22, 2013, 05:53:57 am »
This is a bit off topic, but as an ex-nuclear guy and seeing "when does temperature coefficient matter", I've just been dying to point out something like this.
« Reply #24 on: January 22, 2013, 06:07:25 am »
Umm,  point taken.
