Author Topic: Which simple file-difference software  (Read 4891 times)
Offline Wilson__Topic starter
« on: June 22, 2024, 05:04:44 pm »
How you may recommend a simple software to compare edited source file with original so that we can sure to document the changes.
Many thanks
Offline RAPo
Re: Which simple file-difference software
« Reply #1 on: June 22, 2024, 05:15:21 pm »
Meld]Meld is a good one, If you have git, use git-diff
and for binary files use ImHex
« Last Edit: June 22, 2024, 06:10:55 pm by RAPo »
The following users thanked this post: Wilson__
Offline ataradov
    • Personal site
« Reply #2 on: June 22, 2024, 05:55:57 pm »
On Windows - WinMerge, on Linux - Meld.
Alex
The following users thanked this post: DimitriP, Wilson__
Offline BennoG
« Reply #3 on: June 22, 2024, 06:21:13 pm »
beyond compare
for me that is the only one.
Benno
Online xvr
  • Country: ie
    • LinkedIn
« Reply #4 on: June 22, 2024, 09:23:49 pm »
I have a experience with both Meld and BeyondCompare. On big file BC works well, Meld silently died :(
PS. Good old diff works very well on files of any size, but using it after BC or Meld will be a little painful :(
« Last Edit: June 22, 2024, 09:25:49 pm by xvr »
Online 5U4GB
« Reply #5 on: June 23, 2024, 10:26:58 am »
Another option for Windows is DiffMerge, for people who aren't fans of the angry fruit salad colour scheme used in WinMerge.
Offline zapta
« Reply #6 on: June 23, 2024, 05:26:00 pm »
Another option is Araxis Merge.  I have been using it since 2008 on PC and MAC (my current license is from 2014) and it sill compares favorably with the alternatives.
https://www.araxis.com/merge/index.en
Offline zapta
« Reply #7 on: June 23, 2024, 05:28:20 pm »
If you are diffing in Git, I recommend the free Visual Source Code. Open a folder within your local repository and it will diff it for you as will allow you to modify and submit.
Offline IanB
« Reply #8 on: June 23, 2024, 05:34:35 pm »
Another vote for Beyond Compare.
Offline IanB
« Reply #9 on: June 23, 2024, 05:37:09 pm »
If you are not already using a source control system like git, you really, really, really should be.
Among other things, changes then become self documenting because you can just look at the change history of a file.
Another point is that if you want to know the changes after the fact, then something has gone wrong. You need to plan the changes before the fact, execute them, and then test that they were successful.
The following users thanked this post: RAPo, Wilson__
« Reply #10 on: June 24, 2024, 11:10:44 am »
Many thanks.  sounds like a good idea.
1. Can we run a local git server on Windows 11 or need to use public GitHub?  It is for minimum number of developer and low traffic
2. will git server integrate with Stm32CubeIDE, PyCharm (community edition, free), PlatformIO (free), the traditional Arduino?
Many thanks
Online xvr
  • Country: ie
    • LinkedIn
« Reply #11 on: June 24, 2024, 11:39:17 am »
You can run basic configuration of GitLab (it's open source and free)
If you need to work in distributed team (over global) you could use GitHub of global GitLab.
You can use standalone git with ANY IDE. Some of them have built in support (not sure for the list above)
Offline RAPo
« Reply #12 on: June 24, 2024, 12:47:16 pm »
pycharm has builtin gitlab/github functionality.
platform io has git-cli.
But why not use vs code install platformio, Arduino and STM32CubeMXPIO extensions and use the vs code GitHub/gitlab integration from one central place?
