Author Topic: Who makes and where to buy USB Audio chips?  (Read 26746 times)
Offline cv007
Re: Who makes and where to buy USB Audio chips?
« Reply #25 on: December 13, 2018, 11:13:39 pm »
I have been using a PCM2706 for quite a while as a headphone amp for quite a while (connected to an Onion Omega2 which streams mp3's)-
https://photos.app.goo.gl/RPS3Y58nACGkvy6g7
https://photos.app.goo.gl/XxBw8UcfH3Q2L5iM8
https://photos.app.goo.gl/SM6cY1bLtb5Y6nWf7
I also have one driving my tda8923 boards-
https://photos.app.goo.gl/BiRxAkeJ7mQEmiuU8
(although I recently blew them up when messing with the power supply voltage : ) )
probably not a great circuit board layout as I just wanted something quick, but I'm very happy with the result. I probably do not have golden ears, but it sounds pretty good to me. The music sounds great, and when there is no music its dead silent. You don't need much to get it going and works on any os. I think it makes a good little project that you can easily get working, and if its not good enough you are not out much time and money, or you can hang a dac on it via i2s (which I intended to do, but have never done).
Good test stream-
holiday.stream.publicradio.org/holiday_cms.mp3
Offline amlu
« Reply #26 on: December 16, 2018, 12:15:41 am »
PCM 270* are good enough. 44.1, 48 khz sampling rate, same or more as humble cd audio, 98db SNR, you dont need any more fancy stuff unless if for some high end recording studio or broadcasting equipment.
I got couple of cheapo china ones scattered around for every workstation, some hooked up to pro audio kit and cant really complain about them. big step up from whats built in any laptop or motherboad. Make your own nice board with nice capacitors and off you go.
Offline Smokey
  • Not An Expert
« Reply #27 on: December 10, 2022, 01:50:26 am »
https://www.behringer.com/product.html?modelCode=P0BJZ
> Audiophile 24-Bit/192 kHz resolution for professional audio quality
https://www.audiosciencereview.com/forum/index.php?threads/behringer-umc204-hd-audio-interface-review.9856/
It looks like these guys are using one of these...
https://www.cirrus.com/products/cs4271/
And one of these...
https://www.xmos.ai/download/XS1-U8A-64-FB96-Datasheet(1.8).pdf
NOTE: The forum decides to turn URLs into smiley faces sometimes....  Google "XMOS 8U6C5"
https://www.xmos.ai/software/usb-audio/driver-support/
« Last Edit: December 10, 2022, 01:59:03 am by Smokey »
Offline magic
« Reply #28 on: December 10, 2022, 08:52:00 am »
Your smiley link actually works fine if you click it 8)
Offline eliocor
    • rhodiatoce
« Reply #29 on: December 11, 2022, 01:38:25 am »
SEVERAL years ago I used the UDA1321T
It did exactly what you are looking for.
Somewhere and in some places (according to my inventory) I should have 500 pieces of this component: I do not remember to have thrown them away.
Let me know if you are interested in
Offline jonpaul
  • Analog, magnetics, Pwr high voltage, Audio, Cinema
    • IEEE Spectrum
« Reply #30 on: December 11, 2022, 03:14:49 am »
try AKM, wide line of digital audio ICS
j
The Internet Dinosaur..
passionate about analog electronics since 1950s
