Author Topic: Why Are Circuits on Boards?  (Read 3872 times)
Offline TraderTopic starter
« on: March 05, 2021, 03:24:14 am »
The following users thanked this post: Electro Fan
Offline Renate
    • Renate's Android Page
Re: Why Are Circuits on Boards?
« Reply #1 on: March 05, 2021, 12:00:05 pm »
For quality use point-to-point wiring!
Offline fordem
  • Country: gy
« Reply #2 on: March 06, 2021, 11:35:07 am »
Is this a serious question?  Ease of repair is the answer - and that is six words, six seconds to read, it doesn't need a seventeen minute video to answer.
Offline Doctorandus_P
« Reply #3 on: March 06, 2021, 02:29:52 pm »
Who repairs PCB's these days?
It's just currently the cheapest method to mass produce these things with a quite high reliability.
Offline fubgumfaw
« Reply #4 on: March 08, 2021, 08:11:05 pm »
I started doing component level repair in 1988 as a job. It's been a long time now since I got paid for it, but I still repair lots of things myself for friends. This is not a lost art.
Online TimFox
« Reply #5 on: March 08, 2021, 08:30:37 pm »
The fundamental reason why PCBs took over circuit manufacture is repeatability of construction and performance.
The following users thanked this post: Trader
Offline Stray Electron
« Reply #6 on: March 09, 2021, 03:34:12 am »
  I do! In most cases it's easier to replace one component than it is to replace an entire CCA. Also the Canadian Army does. The US military, not so much any more.  Not many commercial companies do either but MANY individuals do!  Just read some of the forums for Tektronix, HP, LeCroy and other brand names.
   Good luck getting a replacement circuit board from MOST companies! Many don't make or sell spare boards and replace the entire item instead.
« Reply #7 on: March 09, 2021, 03:35:39 am »
 "Why Are Circuits on Boards?"
   Because trees are too hard to move around!  ;D
Offline Dave8266
« Reply #8 on: March 09, 2021, 04:08:26 am »
Circuit boards are the 2.5D solution to a 3D problem.
It's an extremely favorable way to simplify an assembly, for humans, computers, and machines alike.
Online tggzzz
Offline mikerj
« Reply #10 on: March 09, 2021, 09:30:12 am »
There are alternatives, e.g. https://entertaininghacks.wordpress.com/2020/07/22/prototyping-circuits-easy-cheap-fast-reliable-techniques/
Alternatives for prototyping for sure, but nothing really suitable for production.  What else could you mount e.g. a fine pitch BGA with hundreds of pins on other than a PCB of some type?
Online tggzzz
« Reply #11 on: March 09, 2021, 10:09:10 am »
I see you haven't looked at the reference.
If you had you would have seen some pictures of old commercial products, and notes to the effect that some techniques are used in specialised high-end equipment. There are others not shown, of course. Wirewrap and IDC springs to mind. I forget the name of the technique that laid point-to-point wires and buried them in epoxy - great for low volume high density boards without needing many-layer PCBs.
Offline Gyro
« Reply #12 on: March 09, 2021, 12:38:10 pm »
Oh yes, I remember being fascinated by the ads for those in EDN. It must have been late '80s / early '90s. I think their claimed USP was fast turnaround. I think it was only one company that ever offered the process, and was probably scuppered by improved turnarounds on multilayer boards at much lower cost, they didn't survive anyway. I remember thinking that it might end up a bit bumpy with all the overlapping wire junctions crossovers.
Best Regards, Chris
