The LM3886 or TDA7293, get the distortion increased with decrease in frequency. See curve bellow. They are opamp type with dominant pole of less than 20hz. The lower is the frequency, the higher is the NFB, so it must continue to decrease.
Thermal feedback?
This is maybe a red herring, but if it is harmonic distortion in a bandwidth limited system, distortion at higher frequencies may appear to be better because the harmonics are "rolled off".
In an earlier existence, I used to travel around AM Broadcast sites doing annual "routine tests".
These were a bit more intensive than those done prior to & after transmission (this was in the days of staffed transmitters in the city & unattended ones in regional centres).
From memory, we would test for THD at 440Hz in the daily tests, & at 60Hz, 440Hz, & 3kHz in the annual ones.
By & large, the THD of the properly engineered Transmitters became worse at the lower & higher test frequencies, although still in spec.
There were a few transmitters which were quite marginal in many other respects & with them, the 60Hz THD was still a bit worse than at 440Hz but the THD at 3kHz was dramatically better.
When we checked the audio frequency response of these "dodgy" transmitters, "the penny dropped". The usual results for the other transmitters in the network was response, essentially "flat" out to 10kHz, but these ones started to fall quite sharply above 6kHz. The response to the 2nd harmonic of 3kHz was thus very much reduced.
